SolaraGuy.com • View topic - !!!HELP!!! my 1mz fe gets 16mpg
Postby GreenSolara01 » Sat Aug 23, 2008 7:25 pm
I noticed my poor mileage a while ago. since then I have tried...
:evilbat:
Replace air filter
cleaned the MAF
used a fuel cleaner (about 8 times)
replace the plugs
replaced the wires
Changed the oil (synthetic as always)
Changed the Tranny fluid
Replaced Dif fluid as well
Added Injen Sri
Replaced L CV axel (bad boot)
Got and Alignment
Properly inflated tires w/Nitrogen
Lowered car Eib Pro kit
Have had a professional fuel system cleaning
Replaced Fuel cap
Replaced fuel filter and line (oop’s, it was really soft)
:evilbat:
The exhaust smells a little rich, and very humid. I think I might have gotten some bad gas????
However, even w/good gas I’m lucky to get 22mpg. I had an idea! What if when I did my 90k tune up the timing was either accelerated or retarded? How do I check my timing, and A/F??? any ideas?
I am thinking it might be the cat. I don’t have any lights on, and
the ecu isn’t throwing any codes. It’s an automatic and I don't
drive it hard, just average daily driving. I used to get high 20s,
and the price of gas lately 16 mpg is a real big deal.
what kind of gas mileage are you guys getting in your 1mz fe 3.0 v6s, and
any ideas why my mpg’s are so low? :bday: ?
GreenSolara01
Postby Midias » Sat Aug 23, 2008 7:36 pm
Have you tried cleaning you intake manifold and throttle body. Also you could try pulling th battery cables for a few minutes and let the ecu reset its self and then granny drive until it learns not to dump so much fuel in.
Postby Jakecallun20 » Sat Aug 23, 2008 8:24 pm
yeah, the ecu trick oughta do something. I was getting 18 mpgs, but I cleaned my intake manifold, throttle and my TRD filter and changed my oil with mobil one and my last 6.124 gallons got me 151.3 miles which averages out to be about 24 with mixed driving.
Postby dan99solara » Sun Aug 24, 2008 8:53 am
o2 sensor maybe.
1999 Solara V6 5spd 155k miles
TEIN springs. thats it.
dan99solara
Postby no_escape » Sun Aug 24, 2008 9:32 am
are these city miles or highway miles?
no_escape
Postby Camry Racing » Sun Aug 24, 2008 9:45 am
well well another guy like me the difference is that my car throw a O2 sensor code o bank 1 and that should be my problem so my best advice is to check all your o2 sensors
Camry Racing
Postby Dawgz » Sun Aug 24, 2008 10:34 am
dan99solara wrote:o2 sensor maybe.
yes, try that.
Also, i read u changed the fuel LINES but did u replace the fuel filter?
Postby GreenSolara01 » Sun Aug 24, 2008 2:28 pm
I think I will clean the throttle body, EGR and check the timing. Then I will also reset ECU.
It's just weird it drives fine but its using buckets of gas. I went to an ATM at lunch and used about an 1/8 tank it wasn't that far of a trip. I wish It would be a code or something. I hate going at this blind. This seems to be a recurring problem.
GreenSolara01
Postby GreenSolara01 » Sun Aug 24, 2008 2:29 pm
no_escape wrote:are these city miles or highway miles?
mix
GreenSolara01
Postby GreenSolara01 » Sun Aug 24, 2008 2:32 pm
Midias wrote:Have you tried cleaning you intake manifold and throttle body. Also you could try pulling th battery cables for a few minutes and let the ecu reset its self and then granny drive until it learns not to dump so much fuel in.
How did you clean the manifold?
GreenSolara01
Postby Dawgz » Sun Aug 24, 2008 2:43 pm
if ur not sc'd...try seafoam!
Postby GreenSolara01 » Sun Aug 24, 2008 2:46 pm
Dawgz wrote:if ur not sc'd...try seafoam!
I had a pro cleaning about 2-3 months ago. :cry:
GreenSolara01
Postby GreenSolara01 » Sun Aug 24, 2008 2:48 pm
Is it possible when I got my 90k tune up. They advanced the timing by mistake, or would the ECU still catch that?
GreenSolara01
Postby no_escape » Sun Aug 24, 2008 4:15 pm
mix
I'de try these one by one in this order.
1. replace fuel filter
2. reset ECU by disconnecting neg termnial for 15-20sec.
3. Clean TB
4. Clean intake manifold
why I say fuel filter first is the age of the car and you prob don't know when it was last changed.
no_escape
Postby Dawgz » Sun Aug 24, 2008 4:15 pm
GreenSolara01 wrote:Is it possible when I got my 90k tune up. They advanced the timing by mistake, or would the ECU still catch that?
im pretty sure to advance the timing ud need a diffrent kind of belt than OEM...maybe cam gears..i havnt played with that stuff though, but i know if ur timing isnt right, u should be getting a CEL.
