SolaraGuy.com • View topic - brake pad change
brake pad change
brake pad change
Postby mettler » Sun Jul 20, 2008 3:39 am
Is it typical to only change the front brake pads before having to change the back, or do the back and front wear at the same rate?
thanks
http://www.facebook.com/pages/Ice-Dragon-Cooling/139536759426738
mettler
Postby mazen222 » Sun Jul 20, 2008 9:43 am
not 100% sure, but i dont think they wear out at the same rate.... the front go with the pedal brake, while the rear go with the hand brake. Correct me if im wrong
1999, 5 Speed V6
mazen222
Postby DaTwUnKrAziEpInOy » Sun Jul 20, 2008 9:48 am
The front brake pads would wear out faster than the rear pads, your car's braking is mostly done at the front. But the brakes are all running off the pedal. the parking brake ( e-brake) for our cars is a seperate mechanism. You'll go through 2-4 front brake pad sets before you change out the rear pads.
DaTwUnKrAziEpInOy
Postby Mole » Sun Jul 20, 2008 9:48 am
^ you're wrong.
80% of braking is done by the front, 20% rear.
Postby ThurzNite » Thu Aug 07, 2008 2:53 pm
I went to the dealer to get rear pads, and they gave me fronts. I went back and the guy said "solaras rarely need the rears changed, I thought you made a mistake asking for rears."
Dood, no mistake, I need the rears.
ThurzNite
Postby Chinky420 » Thu Aug 07, 2008 7:46 pm
ick, went to the dealer to get pads?!
no wonder they got it wrong
if he thought you were mistaken he shoulda asked.
Chinky420
Postby ThurzNite » Fri Aug 08, 2008 4:35 pm
The local dealer, kragen, and autozone prices were roughly the same.
ThurzNite
Postby mettler » Tue Aug 12, 2008 6:26 am
as much as I have changed brakes in my car I can never figure out an easy way to get the brake-cylinder back into the brake assembly so I can get the caliper back on the rotor.. you have any tricks for that? I usually just slowly push it back in with a little pry-bar sort of thing. Yes, I have the cap off the brake fluid under the hood.
mettler
Postby akora12 » Tue Aug 12, 2008 6:54 am
^^^I use one of these vise-grip c-clamps:
Auto parts stores also sell kits specifically designed to compress the brake cylinder, but they basically do the same thing and cost more.
Postby Jakecallun20 » Tue Aug 12, 2008 6:59 am
Red C clamp works well too.
Postby Midias » Tue Aug 12, 2008 7:15 am
6 inch c clamp all the way
Postby ThurzNite » Fri Aug 15, 2008 12:52 pm
You can clamp the rears in? I thought u had to twist them in? There's 4 notches on the piston, supposed to use the piston turning tool (autozone and kragen let u 'rent' them for free). I use needle nose pliers.
ThurzNite
Postby Midias » Fri Aug 15, 2008 1:04 pm
ThurzNite wrote:You can clamp the rears in? I thought u had to twist them in? There's 4 notches on the piston, supposed to use the piston turning tool (autozone and kragen let u 'rent' them for free). I use needle nose pliers.
Odd my rear does not have 4 notches. Usually if they have notches that is for the emergency brake but I have a drum inside disk emergency brake and a standard piston.
Users browsing this forum: Google [Bot] and 13 guests
