SolaraGuy.com • View topic - TxBmbleBee's Tranny Swap Complete(...sorta)! 2/7/10
Postby TxBmbleBee » Sun Feb 22, 2009 5:59 pm
Props to whom ever guesses what I'll be doing this week :)
And how do I disconnect this from the shifter?
Look what came pre cut out of my firewall haha
hopefully this can help be a guide for others
TxBmbleBee
Postby SpeedySolara » Sun Feb 22, 2009 6:24 pm
Whats the precut for on the 3rd picture?
SpeedySolara
Postby gnegroni » Sun Feb 22, 2009 6:35 pm
Installing the supercharger back AND going 5-speed manual? You DOG!
gnegroni
Postby TxBmbleBee » Sun Feb 22, 2009 6:39 pm
SpeedySolara wrote:Whats the precut for on the 3rd picture?
yep i guess the firewall came pre cut from the factory, that is under my driver side steering wheel where my clutch pedal will mount up.
gnegroni wrote:Installing the supercharger back AND going 5-speed manual? You DOG!
hey what can i say :lol:
i have a lead on a wrecked 99 v6 5 speed where i live. im going tomorrow, i will keep yall updated.
TxBmbleBee
Postby Eye8Pussies » Sun Feb 22, 2009 6:47 pm
you have to hammer/pull the brass clip out
and the cut out is just on the firewall foam- there are punch outs of where you need to drill actual holes for the clutch pedal mounting and the master cylinder though, so just follow those
Postby TxBmbleBee » Sun Feb 22, 2009 8:35 pm
eye8pussies is absolutely correct :D
no more automatic shifter, hopefully for good
where automatic shifter cable enters firewall...
and here are the punch outs for the clutch assembly
TxBmbleBee
Postby ToyoSolV6 » Sun Feb 22, 2009 8:40 pm
wow! thats sick man, keep up the good work and keep us posted.
Postby TxBmbleBee » Mon Feb 23, 2009 2:40 pm
Went to junkyard this morning, and came out with a good part of the stuff I needed...
The shifter assembly
Another pic
Clutch and master cylinder
another pic
manual ecu w/ smaller brake pedal
manual axles..
shifter cables..the idiot that was taking them off ripped one of them (not sure if it is a serious concern or not.) :evil:
full shot of them
here is what sucks, im not an expert...but im pretty sure the mount is not on my tranny. o well i got most of the stuff, so ill quit bitching now :)
cant wait for toyota to rape me on that part haha
TxBmbleBee
Postby Midias » Mon Feb 23, 2009 3:24 pm
Are you going to get a light weight flywheel while you are at it?
Postby Ilovemylara » Mon Feb 23, 2009 4:03 pm
get a fidanza flywheel
Postby TxBmbleBee » Mon Feb 23, 2009 4:14 pm
Midias wrote:Are you going to get a light weight flywheel while you are at it?
yes i am, and either a stage 2 or 3 clutch as well
Ilovemylara wrote:get a fidanza flywheel
fidanza will most likely be the one i get, where do yall recommend i get it, horsepowerfreaks.com?
small update
went to http://www.speed-source.net/ and ordered the shifter base bushing kit as well as the cable bushings
TxBmbleBee
Postby TxBmbleBee » Mon Feb 23, 2009 4:28 pm
comparison of brake pedals
you just have to take out a bolt and a cotter pin to get out the old brake pedal, reverse for install
woohoo, easy peesy now it has to come back off to get spray painted
also quick note, 2 nuts hold in the grey cruise control box, take the box out. and install is sooooo much easier
when you get the clutch pedal assembly, there are two places to plug in wiring
just thought that i would put your mind to ease...my auto solara had these taped up onto my wiring harness, and they theoretically will plug right into the clutch assembly, i know i was worried until i saw.
this proves a lot of theories that the platform is pre made for auto or manual :rock:
i will be cutting the holes in my firewall tonight, ill keep yall updated
TxBmbleBee
Postby DaZanY4002 » Mon Feb 23, 2009 4:41 pm
Wow.. that's a LOT of work lol. :sweet:
DaZanY4002
Postby jetbtkng » Mon Feb 23, 2009 7:35 pm
this is the clutch ass im installing in my solara about $1700,
Clutch Masters is proud to offer the finest and most economical multi-plate clutch systems, the FX600 and FX700 Series. Clutch Masters' Twin Disc systems are pure racing technology that also works well in high performance street applications. They are designed to hold tremendous torque ratings, while retaining a very smooth operation. By using a smaller diameter clutch assembly, Clutch Masters Twin Disc systems have a reduced rotational mass, meaning quicker and smoother shifting and much better throttle response. By slightly increasing the clamping force of the pressure plate and adding to the square inches of usable disc area, CM Twin Discs significantly increase clamping values. The cover assembly is machined from billet aluminum with 25% more tensile strength than the competition's cast unit. They are available in three specific pressure ratings as well as several types of friction surfaces. The flywheel is machined from billet 6061-T6 aluminum to meet SFI spec 1.2 for competition in NHRA, NDRA, IDRC, IHRA, SCCA and NASA.
Postby Eye8Pussies » Mon Feb 23, 2009 11:44 pm
you're going to both need the tranny plate and the tranny mount for your tranny
as for making those holes for the clutch and master cylinder....have fun....lol...it's a bitch.
