SolaraGuy.com • View topic - My Project V6 Turbo Camry (1MZ-FTE) [Nitrous Work page 8]
Postby hksboost » Wed Mar 05, 2008 7:26 am
Hi everyone, today I will share with you my project Turbo V6 Camry (1MZ-FTE).
I started this project last year and at that time my Camry was stock internals and full bolt on and I made it turboed with stock internals and it was running with a boost of 8 psi and today I will share with you my second setup after the forged internals.
My first setup list of mods:
Single turbo TurboNetics T-60
Turbonetics Evolution wastegate
HKS blow off valve
Injectors 390 CC Denso
4 row front mount intercooler
Oil Cooler HKS
7 Heat Range NGK IX Iridium Plugs
Snow Performance water Injection System
3" Turbo Downpipe
2.5" Up-pipe and Collector Pipe
Custom-made turbo heatshield
4" TRUST greddy air filter
Apexi SAFC II
Apexi turbo timer
3" full exhaust system
3" catback TRUST greddy
GM relocated Knock Sensors
Walbro 255LPH fuel pump
SARD in-tank fuel regulator
Max Volt ground system
ported and Polished TB and Intake Manifold
6 puk stage 3 clutchnet clutch
fidanza flywheel
greddy oil filter relocation kit
And after that I decided to rise the boost so I change some of the parts and forged the internals to sustain the high boost and here is the list of the parts I add:
CP racing pistons (8.5:1 CR)
Cometic metal headgasket
ARP head studs
ARP main studs
Turbo XS boost controller
SARD 600cc fuel injectors
CUSCO oil catch can
Greddy E-Manage Ultimate computer
And here are some pictures of the project:
The CP pistons, ARP studs, greddy E- manage Computer and turbo XS Boost controler:
My 1MZ-FTE after installing the CP pistons:
The 1MZ-FTE in my Camry:
The 600CC fuel injectors:
My 1MZ-FTE is almost ready
Start Tuning the computer with Greddy E-Mange Ultimate:
For the first setup on 8 psi my camry put 340 hp on the front wheels
But now I am running 22psi with C16 fuel my camry put 487 hp on the front wheels
For any question i will be more than happy to answer you.
TurboNetics T-60
471 Whp / 467 lbft @ 20 psi
hksboost
Postby CamryOnBronze » Wed Mar 05, 2008 7:43 am
looks like a pretty sick setup! Im really jealous of your internals :(
Postby unbalancedwood » Wed Mar 05, 2008 7:58 am
wow, looking good, dont see many of these flyin around.
and holllyyyy shitt, 486hp!
unbalancedwood
Postby Eye8Pussies » Wed Mar 05, 2008 8:27 am
nice....we never knew that there was another turbo camry out there....
hmmm...so how did the 1mz hold up to 340whp on stock internals?
and also, damn...you dropped the compression by a lot...but I guess that was a much needed drop for t60 on22psi...
Postby Sebas007 » Wed Mar 05, 2008 8:30 am
Really nice setup !! :D
22PSI...that's a lot of sauce !!!
Postby Midias » Wed Mar 05, 2008 8:31 am
Looks good.
Are you using the stock MAF if so have you considered using a supra MAF?
Postby woa_its_j3ff » Wed Mar 05, 2008 8:44 am
ahahah holy sweet sauce.... :D
that is one damn powerful and great lookin' cam, probably the best I've ever seen!
Postby rewmomi » Wed Mar 05, 2008 9:04 am
wow wow weee wow that means holy shi+ nice man I have never seen this kind of set up befor I mean I have sean turbo camerys in mags but not 480+hp one man. sick job man. How much u think u dropped on this project?
rewmomi
Postby SleeperSolara » Wed Mar 05, 2008 9:38 am
Good grief :o
Postby hksboost » Wed Mar 05, 2008 9:52 am
Thank you guys for your replies and comments.
I used my camry for one year with 8 psi of boost and stock internals with no problems at all but you have to tune the car very well and you have to take care for the cooling matter also for more safety use fuel not less than 95 octane.
Yes I am using the stock MAF and I never thought about Supra MAF :roll:
rewmomi
Approximately (13500 $) for both setups.
hksboost
Postby 99V6solaraSE » Wed Mar 05, 2008 9:52 am
very very sick setup.. mad props..
where you located?
99V6solaraSE
Postby Dawgz » Wed Mar 05, 2008 9:55 am
thats the most whp this forum has seen hahahaha.
Postby Dawgz » Wed Mar 05, 2008 9:57 am
did u do the returnstyle fuel rails urself?
also, whats ur transmission? did u beef that up?
Postby hksboost » Wed Mar 05, 2008 10:37 am
99V6solaraSE
Middle East.
I am using the stock 5 spd transmission and the only thing i changed was the 6 puk stage 3 clutchnet clutch and the fidanza flywheel but the Clutch Master and Slave Cylinders give up very quickly according to your drive. :D
I did not change any thing in the fuel rails.
hksboost
Postby Midias » Wed Mar 05, 2008 10:48 am
hksboost wrote:Midias
You may want to consider it because the supra sensor can handle more airflow and it has more space around it for air to flow. A few supercharged people around here have done it.
Return to Forced Induction
