tb spacer
tb spacer
Postby redgen1 » Sat Oct 20, 2007 10:08 am
will a throttle body spacer cause problems with my Cp-e? annnd if not, which spacers do yall recommend?
02 SLE V6
Kaizen *constant improvement*
redgen1
Postby Midias » Sat Oct 20, 2007 1:02 pm
nope does not cause problems and I will copy and paste my standard PM reply
I get his question a few times a month ie a lot so this is a cut and paste if you have questions feel free to ask and Yes I like it and I think it is worth the cash. You will probably be most interested in redknights thread.
Fisrt off you need one from a toyota tachoma more to come from that. Second you need new screws I will be happy so send you a set of screws and washers for 10 bucks shipped. You should get it from www.hubcapsplus.com for best price about 80 bucks shipped read below.
OK here are some old threads
Posted: Tue Jun 06, 2006 12:00 pm Post subject:
OK I got it in. The Home Depot did not have 65mm m8X 1.25 bolts just 70 and 60, so in a lapse of good judgment I got 60mm The fit on the top 2 holes no washer. I will be getting 70 mm eventually. 60 mm does NOT fit the bottom 2 holes. I used the 90 mm that came with it and 2 washers each from the kit; I will probably try 70 mm later on. Other than that install was easy.
How did it feel well it is hot out today so I cannot wait for evening to really have fun but I do feel like midrange has had a nice improvement and I would recommend it as a cheap mod for other people. Second gear feels a lot nicer and the powerband feels smoother. I will try to get pictures soon.
****** Update
On the top use m8 X 1.25 70mm long and on the bottom use 2 of the 90 mm long that came with the kit and 2 washers under each 90 and 1 under each 70mm. You will need to also buy 2 m8 washers for the top sense the kit only comes with 4.
Origional Thread
http://www.solaraguy.org/viewtopic.php? ... e41509aafb
Pictures
http://www.solaraguy.org/viewtopic.php? ... tle+spacer
Redknights report of 20% ariflow increase
http://wheelskin.com/spe-34055.html
Here I found this as the cheapest place, even cheaper than the same company's ebay stuff 79.99 free shipping and enter the coupon code HELIX and get 4 dollars off
Just ordered mine they take paypal yey
I also found a couple a little cheaper on ebay but I wanted the one Greg mentioned.
Postby redgen1 » Sat Oct 20, 2007 9:40 pm
haha thanks midas - how you feelin? roadrash any better?
02 SLE V6
redgen1
Postby Americanctm10 » Sat Oct 20, 2007 9:51 pm
How does it work with the bored out throttle body Midias? Have you tried takin the TB spacer off to see if there is a difference with just ur bored out tb and cp-e? Been thinking about gettin a TB spacer too, thanks for the website, couldn't find it.
Americanctm10
Postby Midias » Sat Oct 20, 2007 10:00 pm
Americanctm10 wrote:How does it work with the bored out throttle body Midias? Have you tried takin the TB spacer off to see if there is a difference with just ur bored out tb and cp-e? Been thinking about gettin a TB spacer too, thanks for the website, couldn't find it.
haven't tried yet been thinking about it but I am still out of the mechanic buisness for a bit.
Postby Midias » Sat Oct 20, 2007 10:04 pm
redgen1 wrote:haha thanks midas - how you feelin? roadrash any better?
Getting better check here for updates just updated a day or two ago
http://www.solaraguy.org/viewtopic.php?t=36201
Users browsing this forum: No registered users and 0 guests
