SolaraGuy.com • View topic - Motor Cuts out at Full throttle??????
Postby RTMiami » Fri May 02, 2008 5:38 pm
Hey guys
I have this 92' Camry Sport 5spd and when I tromp on it in first and second gear, it'll spin up to 3-3500 rpm and cut out completely, come back and then cut out again (constantly)?? It doesn't seem to do it in 3rd and 4th on the hwy, just 1st and 2nd. Is there a hidden traction control I don't know about, or a little gremlin that's pulling off my coil wire??!!
I'm perplexed!! Any idea's? I did a search and really couldn't find anything. Any help is appreciated
Thanks Dale
RTMiami
Postby hskrsolara » Fri May 02, 2008 5:57 pm
replaced your fuel pump or spark plugs lately?
hskrsolara
Postby JavaJoe_2 » Fri May 02, 2008 7:41 pm
My guess would be the fuel filter.
Got Boost?? :sweet:
JavaJoe_2
Postby Midias » Fri May 02, 2008 7:51 pm
Are there MAF sensors in the older camrys? Because mine did the same when it went bad.
Postby JavaJoe_2 » Fri May 02, 2008 8:21 pm
Midias wrote:Are there MAF sensors in the older camrys? Because mine did the same when it went bad.
Wouldn't you pull a code/cel for that?
Got Boost?? :sweet:
JavaJoe_2
Postby (K) » Fri May 02, 2008 9:06 pm
'92s are pre-OBDII so the codes are more sneaky...you can try and pull a code for it but I don't know the procedure for OBDI. Something to do with the amount of flashes, it's a pain in the rear.
Personally just sounds like something's coming loose on hard acceleration. Might have a loose or frayed wire somewhere...I'd check a few grounds.
When you say gut out you mean completely stall out and you have to restart the car right?
(K)
Postby RTMiami » Fri May 02, 2008 10:19 pm
It actually just shuts off (still on full throttle) for about 2 sec's and then comes on strong again. I don't think it's the fuel end of it.
Yeah, I think it's something "electrical" (bad coil, ignitor, etc) as well. Never thought of the MAF thou. I'm gonna do some electrical checks as well as checking all the grounds. Could be the reason I failed my E-test so badly (lol)!!
To check the codes in the older Camrys you have either use an OBD1 scaner tool (big monsterous thing) or use the diagnostic port under the hood and jumper wire(Port E1 to TE1 I think). BTW, here's a good online manual site (library) you guys might be able to use http://arrc.epnet.com.oh0105.oplin.org/ ... autorefctr
Thanks for the help guys. I'll figure it out.
Dale
RTMiami
Return to Toyota Camry
