SolaraGuy.com • View topic - regular oil or synthetic.
Postby bksolara » Wed Sep 24, 2008 11:11 pm
which oil should i use for my next oil change,
bksolara
Postby Mr_Chunkz » Wed Sep 24, 2008 11:29 pm
mobil1 FTW
- Mr_Chunkz -
The Daily
Mr_Chunkz
Postby BChad200 » Thu Sep 25, 2008 7:05 am
i use castrol syntec blend 5w30 and change it every 2k miles. although if you used the mobil one i would definitly leave it in there longer. that shiz is expensive.
2000 Solara SE V6 5 speed- driven for fun
1994 Mazda B3000 SE Cab Plus 2wd Auto- driven for everything else
BChad200
Postby rewmomi » Thu Sep 25, 2008 7:59 am
how about pennzoil platnum 530 i got it for my mom and she did it already with out telloing me should i return it and just order my original oil(eneos 530) or should i just keep the pennzoil
rewmomi
Postby TLMNICK » Thu Sep 25, 2008 8:40 am
Valvoline Full Synthetic is supposed to be extremely good. It was rated almost as high as Royal purple. Amsoil is wicked stuff too.
TLMNICK
Postby dan99solara » Thu Sep 25, 2008 9:50 am
mobil 1 5w30
1999 Solara V6 5spd 155k miles
TEIN springs. thats it.
dan99solara
Postby Mr_Chunkz » Thu Sep 25, 2008 10:55 am
Ive used Royal purple and Eneos before and was told that because those oils are more like "race oil" they lubricate alot more effectively than they protect ( Hence sometimes the increase in HP from freer moving parts ). Because of this, using "race oil" may have contributed to the down fall of my engine ( spun rod bearing from an oil starved motor from excessive blow by ). I'm not sure if it WAS one of the contributing factors, but I was told Mobil1 protects just as well as it lubes so I will stick to what mechanics have been tellin me
- Mr_Chunkz -
The Daily
Mr_Chunkz
Postby Sentinel » Thu Sep 25, 2008 11:36 am
After I had my engine rebuilt under the "sludge warranty" for the 1mz, I have been using whatever synthetic the oil change place has. I get it changed at Toyota's minimum recommended mileage, which I believe is 5k miles.
Previous to the sludge repair I used regular oil and changed it every 3k, just like the petroleum cartel told me.
Sentinel
Postby Midias » Thu Sep 25, 2008 12:50 pm
Valvoline max life 5w30 every 3k miles 160k and going strong no oil burning.
Postby Somedude » Thu Sep 25, 2008 3:10 pm
My Solara uses regular oil 5w-30 Castro GTX, and the oil change is done every 4000 miles. If you care about your car a lot then the synthetic oil is the way to go.
I never used synthetic though, maybe I will switch when the car's milage gets higher (only 26,000+ miles right now).
Somedude
Postby Chinky420 » Fri Sep 26, 2008 8:57 am
i've used both mobil1 5w-30 sythetic
and have also used castrol high milage (>75000 miles) synthetic
http://www.solaraguy.com/viewtopic.php? ... pired+dats
Chinky420
Postby GreenSolara01 » Fri Sep 26, 2008 9:17 am
I have 113k been using RP for a long time, works great.
I would not change from one oil to another. If you haven’t been using synthetic, I wouldn't switch to it. It won’t be good in the long run for your motor.
GreenSolara01
Postby Somedude » Fri Sep 26, 2008 11:36 am
GreenSolara01 wrote:I have 113k been using RP for a long time, works great.
Won't that not matter since you empty the old oil out before pouring the new ones in? The synthetic are just nicer engine oil but not entirely a different substance.
Somedude
Postby dan99solara » Fri Sep 26, 2008 12:07 pm
its ok to switch from regular to synthetic. just dont go back and forth between regular and synthetic.
i bought my solara with like 75k miles on it. the previous owner had always used regular castrol gtx 5w30.
I switched to mobil1 5w30 the first day i bought it and have been using it ever since. i have 155k and still running like new.
dan99solara
Postby aenties » Fri Sep 26, 2008 3:20 pm
I have around 94k on my camry v6 and I'm switching to synthetic this old change.
I will be going to syn-blend (half conventional and half synthetic) then full synthetic from mobil 1 the next oil change.
'98CamryLEV6:
Tokico,Eibach,TrdRSB,Intake,Jim'sTorqueRod.
aenties
