SolaraGuy.com • View topic - timing belt kit
timing belt kit
timing belt kit
Postby mettler » Mon Jun 18, 2007 10:41 am
I am looking at replacing the timing belt and have been looking at different kits. Does anyone have a recommendation? And, what about spark plugs?
thanks
http://www.facebook.com/pages/Ice-Dragon-Cooling/139536759426738
mettler
Postby TOYODRIVER01 » Mon Jun 18, 2007 1:09 pm
you can probably look an ebay for the timing belt kit, it comes with everything..
just go to your local parts store an ask them what spark plugs you need they have from cheap to expensive..
TOYODRIVER01
Postby kwyse » Mon Jun 18, 2007 2:26 pm
I'd recommend biting the bullet and taking it to the dealership for the timing belt. They're the professionals that do it everyday and have experience. It only cost me around $400 with the water pump and drive belts and I figured this was cheaper than me messing everything up trying to do it myself. This is the only time I'd recommend going to the dealership...it hurts for me to say it.
kwyse
Postby mettler » Mon Jun 18, 2007 3:42 pm
I have a friend here whose family owns a car shop. He has always done the complicated car work for me, but I usually buy the parts and just bring the car to him. So, I was looking online at timing belt kits and spark plugs. I wasn't going to do the water pump, but since it is all apart I think I will get one of those too.
thanks
mettler
Postby 99V6solaraSE » Mon Jun 18, 2007 3:45 pm
i was gonna go in for my 90k maintenance. And i was quoted @ 955$ :o
does that sound about right?
278.10 for doing the regular stuff.. the inspections, lubricating, topping off fluids,etc
289.95 timing belt "special"
249.95 water pump
drive belts 55
man.. now im thinking of just getting some of that on my own. then i guess i could get them to install it.
but worried that i wont be safe though...
http://cgi.ebay.com/ebaymotors/Toyota-C ... enameZWDVW
does it look legit? and how would i know if its quality parts?
99V6solaraSE
Postby KeepItSimpleStupid » Mon Jun 18, 2007 7:58 pm
Just had a timing belt etc. done at the dealership at 60K miles. Drive belts were a given. Water pump just made sense. Crank seal would be done based on inspection. I said do it anyway. I know what happens when the seal gets hard. I timed the coolant change and flush to occur at the same time.
KeepItSimpleStupid
Postby SolaraGuy22 » Mon Jun 18, 2007 8:26 pm
I just got my box of goodies today actually. Thanks again Reggie!
Tbelt 13568-09080
waterpump 16100-29085
ac/alt belt 90916-02401-83
p/s belt 90080-91088-83
thermostat 90916-03129
thermostat gasket 16325-62010
crank seal 90311-40022
transpan gasket (automatic) 35168-33031
atf fluid 00718-ATF00 (5)
air filter 17801-03010
efi cleaner 08813-00080-DS
and my RSB to all be installed this week WOO HOO!
SolaraGuy22
SolaraGuy Pimp
SolaraGuy Pimp
Postby Midias » Mon Jun 18, 2007 8:30 pm
99V6solaraSE wrote:i was gonna go in for my 90k maintenance. And i was quoted @ 955$ :o
249.95 water pump
drive belts 55
I think I paid 460 for all that - the inspection.
Postby 99V6solaraSE » Mon Jun 18, 2007 9:01 pm
so u got 460 for the timing belt, water pump, and 90 k maintenance?!?!? You actually bought the stuff from them and i still only cost that much in total?
99V6solaraSE
Postby SolaraGuy22 » Mon Jun 18, 2007 9:08 pm
That's a hell of a deal. I got quoted $650 for all that so I said to hell with it and got the parts from Reggie for 1/3 of the cost.
SolaraGuy22
SolaraGuy Pimp
SolaraGuy Pimp
Postby 99V6solaraSE » Mon Jun 18, 2007 9:10 pm
whos reggie.. and is he still selling all that stuff lol
99V6solaraSE
Postby aleki2424 » Mon Jun 18, 2007 9:15 pm
actually, i just got a quote for the tbelt , valve cover gasket, w pump and front brakes at slightly over 500. i thinks thats fair
now 900 dollars for that stuff is total b.s. i would think
aleki2424
Postby SolaraGuy22 » Mon Jun 18, 2007 9:24 pm
99V6solaraSE wrote:whos reggie.. and is he still selling all that stuff lol
Reggie (NVDIS1) works at Toyota in St. Louis and can get all the goods. I got my RSB from him a few weeks ago and then I ordered all the stuff listed above from him the other day.
http://www.cardomain.com/ride/368788
SolaraGuy22
SolaraGuy Pimp
SolaraGuy Pimp
Postby deus85 » Mon Jun 18, 2007 9:37 pm
I got my stuff from www.azautohaus.com They're located in Arizona, and I received my order three days after placing it. I figured rather than spending more money to by OE stuff from the dealer, the OEM stuff found there wouldn't be bad.
Changing the timing belt and water pump really isnt that bad once you've figured everything out. It took me awhile (days) because I didn't know the right technique to removing parts.
The advice I can give you:
1. Removing the crankshaft was pretty tough because it kept turning. I finally just put a socket on the bolt and stuck a cheater bar in. Then very briskly start the ignition for a split of a second and that will do the job. Then rent a pully puller from Autozone to pull it out.
2. I had the same trouble with the two camshafts. Don't remove the tensioner yet. I used the timing belt tension to remove those bolts (only do that if you're going to replace the belt.
3. Read the manual carefully and torque to in-lbs when it say in-lbs not ft-lbs...I did that with the water pump bolt and it took two days to order that bolt (just over $1) from the dealer.
Anyones welcome to ask for more advice.
BTW, it was a V6 that I worked on.
deus85
Postby Midias » Tue Jun 19, 2007 3:25 am
99V6solaraSE wrote:so u got 460 for the timing belt, water pump, and 90 k maintenance?!?!? You actually bought the stuff from them and i still only cost that much in total?
no just 460 for the belt pump and drive belts
