SolaraGuy.com • View topic - Check engine light is on.
Postby Parke10 » Fri Jun 10, 2005 12:21 am
it might be the cap again
when u tighten it it has to click a few times if not itll throw the codes
Parke10
Postby Turbosolara » Fri Jun 10, 2005 1:16 am
so you never replace your fuel cap?
Postby Midias » Sun Jun 12, 2005 3:28 pm
Probably your charcoal canister
Re: Check engine light is on.
Postby solarafan » Wed Jul 23, 2014 9:43 pm
The Check Engine Light turned on in my 2000 SLE V6. I had the code diagnosed and one of the possibilities was a loose fuel cap. When I unscrewed the fuel cap, I did not hear the pressure release as usual. I tightened the fuel cap and drove for a while. I then disconnected the negative from the battery to reset the Check Engine Light. The Check Engine Light did not turn on again. I went to the gas station to refuel and when removing the fuel cap, I heard the pressure release as usual. As it turned out, it was just a loose fuel cap.
solarafan
Postby crankine3 » Fri Jul 25, 2014 7:31 pm
Get a cheap OBD2 Bluetooth adapter and the Torque app (for Android). Find out what the code is.
crankine3
Postby ThatVietGuy » Sat Jul 26, 2014 12:55 pm
Holy zombie thread, Batman.
ThatVietGuy
Postby crankine3 » Sat Jul 26, 2014 1:13 pm
Opps ;(
crankine3
Users browsing this forum: Google [Bot] and 28 guests
