SolaraGuy.com • View topic - UR Front lower 4-point brace - Gen 5 Camrys (Gen 2 Solara?)
Postby Mr_Krispy1183 » Thu Feb 26, 2009 3:30 pm
Hey guys,
Don't know how many of you venture over into the Gen 1 section, but I recently was the guinea pig for a suspension piece made by Malaysia-based Ultra Racing who surprisisngly makes quite a few pieces for our cars. I was a guinea pig in the sense that the 4-point bar I bought was built for the JP/Asia-spec Gen 4 Camry, so it was a shot in the dark for me to buy it, and luckily it bolted up perfectly to my Gen 1 Solara!
Now, as for relevancy to you Gen 2 guys, there is a similar (and much cooler looking) brace available for the Gen 5 Camrys, pics here: http://www.ultraracing.com.my/Bars.asp?ID=2568
So hopefully, with any luck, this should be a direct bolt-on suspension piece for you guys.
As far as the benefits I personally can vouch for the bar on my Solara:
-As I first drove around the car felt more secure, stable, controlled, stiff, and durable.
-Cornering has improved drastically; there is obviously still lean-in, but not nearly as much as stock (Combining this with an RSB would be a big plus!)
-Turning longer sweeps have become even more fun and sporty
-Going over uneven pavement has improved to the point where you don't have to tense your whole body in anticipation of whats ahead; it's much more composed
Just figured I'd pass the info along.
Postby aenties » Thu Feb 26, 2009 11:03 pm
I actually did a google of the part number you gave us (UR-LA4-366) in your original post and came up with this thread at TN. Its about the strut bar and I know somebody on there has tried the lower brace on the gen 6.
http://www.toyotanation.com/forum/showt ... UR-LA4-366
'98CamryLEV6:
Tokico,Eibach,TrdRSB,Intake,Jim'sTorqueRod.
aenties
Postby Mr_Krispy1183 » Thu Feb 26, 2009 11:39 pm
Actually, after searching around the UR site more, it appears the brace I posted above might be relegated to fitting on the Asia Spec Camry that is a bit more different than our US Gen 5.
Compare this car Image
to this car Image
In seing that, I saw that there was another category for the ACV36 chassis that has different parts for it (a different 4-point brace being one of the)
http://www.ultraracing.com.my/Bars.asp?ID=3168
I get the feeling this one would be more suited to Gen 2 Solaras seeing as the car in this picture is much more reminiscent of the US-spec Gen 5 (ACV30, which the Solara is based on).
Last edited by Mr_Krispy1183 on Thu Feb 26, 2009 11:46 pm, edited 1 time in total.
Postby aenties » Thu Feb 26, 2009 11:40 pm
^^ That looks beefy
'98CamryLEV6:
aenties
Postby Mr_Krispy1183 » Thu Feb 26, 2009 11:48 pm
^True. Mine's built the same, just that the 2 outer mount points connect to make a trapezoid. I think it's just the angle of the stock photo UR uses that makes the Gen4 bar look more anemic and puny.
Postby aenties » Fri Feb 27, 2009 1:01 am
haha nice, I'll be getting the brace for my camry. :)
'98CamryLEV6:
aenties
Postby PXLpainter » Sat Feb 28, 2009 4:04 pm
Okay - so who's gonna be the Guinea Pig for this bitch on a Gen 2 Solara?
C'mon guys - I had a major fukkup with the Whiteline FSB (ask Milton who helped me with that bitch both install and un-install!) :-?
Postby Mr_Krispy1183 » Sat Feb 28, 2009 5:41 pm
^Cmon PXL, do it! This bar wouldn't be nearly as complicated as the RSB (although I understand your reluctance).
Postby PXLpainter » Sat Feb 28, 2009 5:43 pm
I have Zero ($0) funds right now, so it's not going to happen any time soon. Too many other things I need to replace/repair before putting any more into mods right now. :(
Postby v6secamry » Sat Feb 28, 2009 6:07 pm
hey guys, i have the 2004 camry pretty much same chassis are you gen 2s. My 4 pt bar is on the way. I will take pics when i get it in :)
v6secamry
Postby anwagbo3000 » Sat Feb 28, 2009 6:09 pm
so i am searching the site and do not see any prices, i might want to be the little piggy on this one, but i need a price and i can not find any prices of it
anwagbo3000
Postby Mr_Krispy1183 » Sat Feb 28, 2009 7:01 pm
^Ultra doesn't do business with the public. The retailer I bought the bar from was evan@nextgentuning.com Evan Carollo at http://www.nextgentuning.com. He's good peoples.
Postby v6secamry » Sat Feb 28, 2009 9:00 pm
yeah i order my bar from evan also. good guy
v6secamry
Postby Mr_Krispy1183 » Sat Feb 28, 2009 9:10 pm
^Just out of curiosity v6se, which one did you purchase, the square one or the 3/4 trapezoidal one? I'm still not clear which would be a sure fit for our (US) Gen 5s.
Postby v6secamry » Sat Feb 28, 2009 9:17 pm
i purchase the first one you posted. evan said that was it. I know the gen 6 camry(07+) use that bar also
v6secamry
Users browsing this forum: Google [Bot] and 10 guests
