SolaraGuy.com • View topic - Cleaning the MAF, Help Please
Postby treefrog99 » Wed Mar 17, 2010 6:36 am
Hey all,
So I am cleaning my MAF today, doubt its ever been done and the car has 240,000km on it SOOOO it probably needs to be cleaned lol
So I took out the MAF, now whats my next step? How do I get at those little wires that actually need to be cleaned.. im assuming I need to take this apart some how? If you guys have any links or videos that would be great too!
THANKS!
There is no such thing as strong coffee, only weak people.
treefrog99
Postby 99BlackSandv6 » Wed Mar 17, 2010 8:39 am
No don't take it apart. It's very delicate, use an aerosol MAF sensor cleaner.
You can get it at pretty much any auto parts store.
Postby treefrog99 » Wed Mar 17, 2010 9:12 am
Ok well this is where I am confused.. watch this..
http://www.youtube.com/watch?v=gd640ImE9Ec
Go to about 2:03, see how he is cleaning the actual MAF sensor, the actual wires... how would I do that on mine? Or do I not need to do that?
See why I am confused? lol
treefrog99
Postby ASG14 » Wed Mar 17, 2010 9:17 am
Your confused because you want to do what you want. Get a MAF/Electronics parts cleaning spray. End of story. I did mine last night.
ASG14
Postby treefrog99 » Wed Mar 17, 2010 9:59 am
So I just spray it right in the big opening there, and thats it?
I have an Air Intake Cleaner (aerosol spray)... can I use that?
treefrog99
Postby ASG14 » Wed Mar 17, 2010 10:22 am
No, MAF or Electronic parts cleaner ONLY. It;s a sensitive piece. Spray it onto the wires. Hold it upside down so the liquid comes out. Let it dry, then reinstall it.
ASG14
Postby Akfahad » Wed Mar 17, 2010 11:00 am
x3 or x4...whatever it is, don't take it apart, use ONLY a MAF/Electronics cleaner. You can get MAF cleaner @ Autozone/Adv. Auto Parts/etc. Shoot it in there, let the liquid drain and dry and reinstall = done
Postby 99BlackSandv6 » Wed Mar 17, 2010 11:34 am
The reason you only use MAF/electonics cleaner, is that carb or
intake cleaner may also contain lubricants. You only want the
solvent. Lubricants contaminate the hotwire, and is the exact
thing you are trying to remove.
In case you were wondering. :wink:
Postby SirThomas8 » Wed Mar 17, 2010 8:02 pm
If you look down into your MAF, you should be able to see the same wires as in that you tube video. Therefor if you can make eye contact with it there is no reason the spray can't reach it.
So... Shoot the spray down into it man! The MAF cleaner is alcohol based so it will dry relatively quickly. Don't worry you won't mess anything up.
SirThomas8
Postby treefrog99 » Fri Mar 19, 2010 7:33 am
Alright thanks guys!!!!! I understand now haha just takes awhile sometimes... And I liike to be absolutely sure of things before I do them
treefrog99
Postby treefrog99 » Fri Mar 19, 2010 10:59 am
One last question in regards to this!!!
Would this be safe to use on my MAF?
It IS for electrical components too, and is non-flamable and non-conductive... and it does not have an "oil" in it... THANKS
treefrog99
Postby treefrog99 » Fri Mar 19, 2010 11:49 am
^^^ FYI the reason I bought this was because none of the local stores had an actual MAF cleaner.. Guys at NAPA didn't even know what I was talking about
treefrog99
Postby no_escape » Fri Mar 19, 2010 3:30 pm
I would think it would be ok since it says electronics cleaner.
That's what you ask for next time, electronics cleaner. I asked the same thing at advanced and he said, "You want electronics cleaner."
no_escape
Postby alltrac92 » Fri Mar 19, 2010 7:33 pm
$7.74 at Amazon
http://www.amazon.com/CRC-05110-Mass-Se ... 312&sr=8-1
Or $6.99 at O'Reilly auto parts.
alltrac92
Postby SirThomas8 » Sat Mar 20, 2010 7:12 pm
It might be okay but I'd say to be safe, just get a hold of actual MAF cleaner. Not worth taking chances when you can just spend a little more effort and another $7 getting actual MAF cleaner and avoiding any potential problems.
SirThomas8
