SolaraGuy.com • View topic - Help:: No Turn Signals
Postby illstylez » Fri Feb 27, 2009 2:11 pm
Hey Im back again! :) Did a search but couldnt find any results colse enough to what I have going on.
My turn signals just stopped working this week, I have no idea what happened. I checked all the fuses inside and in the engine compartment..all appeared to be in working condition :(
Has anyone else had this problem or can give me some idea on what the source may be? Thanks in advance.
Kentel " Ill " Styles
Chicago IL,
99' Solara Since 2007
" The best way to predict the future is to create it! "
illstylez
Postby BLACK V6 » Fri Feb 27, 2009 2:13 pm
I dont know much about it but just an idea. There is a little flasher thing that looks kind of like a relay that controls that speed of the flash of the signals. I would image that if that goes bad your turn signals wouldnt work. Just an idea, I dont know much about though so dont hate. :D
BLACK V6
Postby fzzyrn » Fri Feb 27, 2009 2:17 pm
i'm not completely familiar with how the turn signals work. but maybe the bulbs are out?
fzzyrn
Postby illstylez » Fri Feb 27, 2009 2:20 pm
Little more info:
My headlights and brights all function, as well as my interior lights, and dash lights. Just my hazards and turn signals do not function ??
Chicago IL,
illstylez
Postby (K) » Fri Feb 27, 2009 2:56 pm
BLACK V6 wrote:I dont know much about it but just an idea. There is a little flasher thing that looks kind of like a relay that controls that speed of the flash of the signals. I would image that if that goes bad your turn signals wouldnt work. Just an idea, I dont know much about though so dont hate. :D
I agree here. Probably have a bad flasher. I never thought those could ever go bad but you never know.
(K)
Postby illstylez » Fri Feb 27, 2009 3:04 pm
Where do I find this relay? And how do I know if that is the source once located?
Chicago IL,
illstylez
Postby 5sfe » Fri Feb 27, 2009 7:14 pm
i know your problem, check and take apart your dash, i mean where the radio and a/c control unit is and make sure your hazards button is connected, if the hazards are disconnected the turning singals don't work
5sfe
Postby Mole » Fri Feb 27, 2009 8:43 pm
^ yup.
Postby 5sfe » Sat Feb 28, 2009 10:55 am
i need more details about your problem, in your dash board do you see the green arrows come on when you engage the turning singal, do you hear clicking as well when you engage your turning singal?
5sfe
Postby illstylez » Sat Feb 28, 2009 4:55 pm
OK so I just pulled the out the center console trim for access to the hazard connection. Everything was connected there. No loose wires and it was seated firmly in the connector.
i need more details about your problem, in your dash board do you see the green arrows come on when you engage the turning signal, do you hear clicking as well when you engage your turning signal?
I do not hear the clicking and there is no lighting for the blinker on the inside dash or outside on the front or rear blinkers :( Really stumped by this one. Any other suggestions. I was hearing that the fluid or something goes bad around here somewhere, and someone suggested checking the relay, but I don't know where to locate this relay :( Really concerned cuz I live in the Chi don't want people running me over cuz they don't know which way I'm going.
Chicago IL,
illstylez
Postby illstylez » Sun Mar 01, 2009 12:49 pm
BUMP
Chicago IL,
illstylez
Postby illstylez » Mon Mar 02, 2009 9:50 am
bump* :(
Chicago IL,
illstylez
Postby 5sfe » Mon Mar 02, 2009 10:25 am
check your fuses, other than that i will have to look at it personaly which can't happen because, im in florida, do you have a factory alarm
5sfe
Postby illstylez » Mon Mar 02, 2009 11:19 am
No, no alarm at all on this one.
Chicago IL,
illstylez
flasher location
Postby D-money » Mon Mar 02, 2009 12:09 pm
If you look up under the steering colum and look to the left you will see a 1in black square box pluged into a fuse box thats it .i have had the same problem and my flasher relay did go bad .I dont know how to test it but if you buy a new one and it doesent fix your problem you can always return it.hope this helps
D-money
