SolaraGuy.com • View topic - Rear Wheels
Rear Wheels
Rear Wheels
Postby SpeedySolara » Tue Sep 16, 2008 11:19 pm
My rear wheels make a humming sound while I drive. Do I need the hub and bearings or should I just buy the bearings alone?
SpeedySolara
Postby rt9101 » Wed Sep 17, 2008 11:41 am
Knowing new cars you can't just buy a bearing because it's probably sealed into the hub. If you can and you are sure it's the bearing, just do the bearing unless something else is broken on the hub. The parts store should be able to tell you. Or tomorrow at school I could check Alldata...
rt9101
Postby theprodigy79 » Wed Sep 17, 2008 1:30 pm
If it's humming it may be a tire sound, which could be attributed to uneven wear (need alignment), or they may simply be unbalanced...
What else is leading you to conclude that it's a bearing issue?
theprodigy79
Postby SpeedySolara » Wed Sep 17, 2008 9:56 pm
I doubt its the wheels/tires because I've used my TRD rims and my SLE rims and the noise is still there. Its gotten louder in the last few months and its really annoying me. The noise is coming from the rear wheels so I'm assuming/making a wise guess its the bearings. Truly I'm uncertain though, I'm far from being a mechanic.
SpeedySolara
Postby (K) » Thu Sep 18, 2008 12:51 am
Does it make that sound when you're accelerating or braking?
(K)
Postby rt9101 » Thu Sep 18, 2008 6:26 pm
If it's a bearing it won't matter. Is it more of a humming or a grinding?
rt9101
Postby indiglosolara » Thu Sep 18, 2008 9:39 pm
its the rear hub.... I think its all one assembly but not 100% sure
indiglosolara
Solara 2 xB
Solara 2 xB
Postby SpeedySolara » Thu Sep 18, 2008 9:54 pm
As I go faster the noise gets louder. As long as the car is rolling, it will make that sound, even if the car is turned off. I compare the sound to that of knobby off road tires although its not exactly like it.
SpeedySolara
Postby ptballer » Thu Sep 18, 2008 9:55 pm
Change out the wheel bearing I had the same problem and I just replaced it very easy to do yourself. This is what the part looks like Image
ptballer
Postby rt9101 » Mon Sep 22, 2008 3:26 pm
sounds like a wheel bearing, but I can't be definate without hearing myself. Jack up the rear end and try to wiggle the rear wheels in any and every direction. If they definately move, it's a pretty good chance it's the bearing. If you're not sure don't risk it.
rt9101
Users browsing this forum: Google [Bot] and 12 guests
