SolaraGuy.com • View topic - help w DIY*code-PO401 EGR flow insufficient detected.again!!
Postby LatinUSMC » Wed Jul 16, 2008 5:52 pm
my CEL came on again.(EGR valve insufficient flow).i took it to the shop he said he cleaned it...but about a moth later its back on..i have time on the weekend to do it my self now any recommendations, or shoud i just buy a new egr valve? what kind of cleaner spray is safe?????????
2001, i4, 5Fse, auto, injen intake..
original thread....
http://solaraguy.com/viewtopic.php?t=37 ... =egr+valve
LatinUSMC
Re: help w DIY*code-PO401 EGR flow insufficient detected.aga
Postby Dawgz » Wed Jul 16, 2008 6:06 pm
LatinUSMC wrote:my CEL came on again.(EGR valve insufficient flow).i took it to the shop he said he cleaned it...but about a moth later its back on..i have time on the weekend to do it my self now any recommendations, or shoud i just buy a new egr valve? what kind of cleaner spray is safe?????????
original thread....
i recently cleaned mine out @ adams house with some Carb cleaner.
Itll do the job.
Postby LatinUSMC » Wed Jul 16, 2008 6:07 pm
:drinking: :drinking: :drinking: cool thx.. whats the cause.. so soon (jan.08)any idea?
LatinUSMC
Postby 1gSE » Wed Jul 16, 2008 6:10 pm
i don't think it's a big deal. I took mine off and put it back on in a couple off minutes. I'm sure any kind of throttle body cleaner would be fine. I expected to see a crap load of carbon build up on mine, but there wasn't. I reset the ecu and there hasn't been a problem since (about 4 months ago) If you can use a ratchet, i definitely recommend doing this yourself, instead of paying for it. A parts store would more than likely have to order it. I called checker for a price and i was looking up the same part online and i could have ordered it for 100 bux less. But i didn't need it soo.....good luck!
Solara-M62 @ 5.5psi
1gSE
Postby Dawgz » Wed Jul 16, 2008 6:35 pm
when i recently hit mine with some carb cleaner, alot of gunk came out with the liquid...good thing i cleaned it!
Postby 5sfe » Wed Jul 16, 2008 7:02 pm
it could be alot of things i had my solara about 1 year and ever since i had that code..i put a new egr cleaned out the tube a new egr vacum switch the only thing thats left is my modulater...which is going to be change soon i hope thats my problem
5sfe
Postby Camry Racing » Sun Jul 20, 2008 11:21 am
Damm I got same problems I got that cell on but got the 2 codes insufficient egr flow or to much air flow
Camry Racing
Postby TheTamago » Sun Jul 20, 2008 11:38 am
yup same here.. Except i don't have the resources to clean the EGR or make sure it ain't the sensor. 5SFE engine. My CEL bounces on and off. Takes awhile to turn off though. Maybe after 6cycles of turning on/off the engine with 5-10mile trips 1 way.
TheTamago
Postby GreenSolara01 » Thu Sep 04, 2008 9:02 pm
GreenSolara01 wrote:Code came back. Also I checked the EGR. It doesn't have a vacuum. Funny thing is I checked the position sensor and it's bad too. not LOL not at all
GreenSolara01
Postby rt9101 » Mon Sep 08, 2008 1:18 pm
5sfe wrote:it could be alot of things i had my solara about 1 year and ever since i had that code..i put a new egr cleaned out the tube a new egr vacum switch the only thing thats left is my modulater...which is going to be change soon i hope thats my problem
This is it, the VSV or Vacuum Switching Valve or the modulator. I know, I went through and nobody in the world could tell me what a VSV was, so I did that research thing. I had already cleaned, changed, and swore at my EGR, and it was not defective. One easy way to see if it has flow is just to pull up on the bottom of the diaphragm and if it kills the engine it's flowing.
This does sound exactly like the problem I had though, so look into this VSV...sadly they're about 90 bucks
Find out how much a modulator is and if you can't test yours, replace the cheapest.
rt9101
Postby GreenSolara01 » Mon Sep 08, 2008 7:29 pm
I am in the process of replacing my EGR, they are not cheap. You should check the diaphragm the operates the valve. Put a hand vacuum on it, and see if it can hold a steady vacuum for a few minutes, and your car should run bad. If that diaphragm vacuum fails you will need a new EGR.
GreenSolara01
Users browsing this forum: Google [Bot] and 5 guests
