SolaraGuy.com • View topic - LSD Speedo Drive Gear
Postby EricSol » Sun Jan 17, 2010 9:46 am
I have the KAAZ LSD installed with the MR2 bigger ring speed gear. The speedo drive gear on my VSS is stripped, need the part number for the correct one. Can't remember if you use the one off a '91 MR2 (mechanical speedo) or '92 (Electric).
I forgot about the different drive gear on the KAAZ and installed a speedo gear for a Solara, lasted a week b4 stripping but seemed to display the correct speed.
Thanks, Eric
2004 Pontiac GTO 408ci 535 whp all motor
1999 Solara 296 whp
EricSol
Postby trd4life » Sun Jan 17, 2010 10:16 am
Driven Gear, Speedometer 33481-12100
Ring, Snap 90520-99011
Bolt, Washer Base: 90105-12150 x16 (bolts for drive gear)
Postby EricSol » Sun Jan 17, 2010 10:50 am
trd4life wrote:Driven Gear, Speedometer 33481-12100
That is for the gear at the end of the vss or the one on the LSD itself? I need the one at the end of the vss.
1999 Solara 296 whp
EricSol
Postby trd4life » Sun Jan 17, 2010 11:38 am
*most* of the LSD's require the 93+ MR2 LSD differential gear bolts and the 93lsd speedo gear & retaining clip
Postby EricSol » Tue Jan 19, 2010 7:32 am
The gear at the end of VSS was a 28-35 (stock 99 solara). I has 28 teeth and I'm assuming the 35 is a reference to pitch. The MR2 I ordered was a 30-35, lets hope it lasts longer then a week.
1999 Solara 296 whp
EricSol
Postby trd4life » Tue Jan 19, 2010 9:17 am
let me know how that turns out k
Postby EricSol » Sat Jan 30, 2010 9:20 am
EricSol wrote:The gear at the end of VSS was a 28-35 (stock 99 solara). I has 28 teeth and I'm assuming the 35 is a reference to pitch. The MR2 I ordered was a 30-35, lets hope it lasts longer then a week.
The MR2 gear is a couple of mm's less in diameter. Went out last night and hung the thing at redline in 5th gear with no issues. The stock Solara gear strips at 100mph, this one was fine at 142mph + 8% ~ 155mph. Yeah the speedo's 8% slow now......
1999 Solara 296 whp
EricSol
Users browsing this forum: No registered users and 128 guests
