SolaraGuy.com • View topic - Ultra Racing 4-point lower brace (Update/new parts pg 3)
Postby Mr_Krispy1183 » Fri Feb 20, 2009 6:08 pm
Alright guys, I'll start a fresh thread for this. I, with the assistance of a buddy, installed the brace this morning.
After installation, going through some twisties and streets here in the Valley, I noticed the brace did indeed improve the car's behavior quite significantly on corners, helping keep the front tires from squealing/breaking loose as easily as stock. It also helps negate the wandering steering that results from Teins/Tokicos/18" WORKs w/low pro rubber. Lastly, I noticed the car is much more composed on uneven roads than before. I used to cringe when I'd get to crappily paved roads, now it's noticeably better. A TRD RSB and Whiteline FSB teamed up with this thing would likely make for quite the handling beast (for being a Camry).
First off, I must say, white is the absolute CRAPPIEST color for such a suspension piece. I'm contemplating taking it off in the future and getting it stripped and powdercoated gloss black in the future. Damn Malaysians....lol j/k. Forgive the blurry/not-so-great pics, I don't have the ends to get with the fancy DSLR crowd. Also, the bar went on dirty due to greasy mechanic gloves and being laid down on a dirty shop floor. Oh well, it's underneath the car anyhow.
Here's the pic from the old post of the bar still in its poly bag/plastic wrap:
And fast forward to earlier where me and the homie Johnny got to sticking the Solara on a lift to get underneath and test fit
Unfortunately, we discovered that this isn't quite as quick an install as we thought. The 2 outward-most mounting points are (in)conveniently shielded by part of the inner fender liner trim. After locating the bolts/mounting points that we needed to find, we undid (1) small bolt on each side of the car that's holding on the bottom part of the fender liner trim to access the larger bolt needed to mount the brace. We also cut a square opening into the liner trim large enough for the round lip of the brace to enter to be mounted
After the holes were cut, the fender trim was reinstalled and the bolting in of the brace was pretty straightforward
NOTE/WARNING! I knew going into this that this would reduce ground clearance. Not too much, but for those of you with coilovers or who encounter a lot of raised manholes/other raised road hazards should be careful with this brace installed.
If you're interested in purchasing one, contact Evan at http://www.nextgentuning.com, Ultra Racing part #UR-LA4-366. $149 + shipping, only downside is you must await arrival from overseas. Post if there are any other questions.
Last edited by Mr_Krispy1183 on Sun Mar 15, 2009 9:56 pm, edited 5 times in total.
Postby ASG14 » Fri Feb 20, 2009 6:31 pm
Did you measure the distance from the mounting points?
ASG14
Postby Mr_Krispy1183 » Fri Feb 20, 2009 6:37 pm
Adam,
I'm sorry! Didn't get to, since I was in a rush to get to work. However, I will do so in the following days and post the dimensions here.
Postby ASG14 » Fri Feb 20, 2009 6:39 pm
Please do. I plan to see if this will work ont he Gen 3 since it looks damn good on your car (minus the flippin white)
ASG14
Postby Akfahad » Fri Feb 20, 2009 7:14 pm
sexy!!! what y-pipe are you running, stock, Dats, JP? Just curious if it would clear my JP in particular...
Postby Toy1mzfe » Fri Feb 20, 2009 8:16 pm
Ouch. that looks friggin low... i carve speed bumps now, so doubt i will go with this.
Looks like its pretty effective. Not as meaty as i thought but better than nothing.
Good stuff for buying it and being a test dummie man.
Postby Mr_Krispy1183 » Fri Feb 20, 2009 8:17 pm
^No prob Kevin, someone had to be the test dummy/guinea pig, so I'm happy to be it for once. True, it's not super beefy, but surprisingly it makes quite the difference, even more so I'm sure when combined with front/rear sway bars. I'd be scared to have this on your car as well, seeing as how dumped you are.
Postby ASG14 » Fri Feb 20, 2009 8:28 pm
To me, it looks as if it may not be as low as the picture makes it out to be.
How much are you lowered?
ASG14
Postby Mr_Krispy1183 » Fri Feb 20, 2009 8:36 pm
I'm lowered on Tein S-Techs that are well-settled, so I'd say about 1.8-1.9" up front. I'll break out the tape measure and camera in the AM to show the clearance.
Postby funboy102 » Fri Feb 20, 2009 9:39 pm
Thanks for experimenting with this for us! Is this pretty much impossible to install w/o a lift?
(Btw, that's a Vietnamese mechanic shop huh? I'm Viet and I know one when I see one, haha)
funboy102
Postby Toy1mzfe » Fri Feb 20, 2009 10:54 pm
^^^ im chinese but know who does slick back hairs. haha
Postby SleeperSolara » Fri Feb 20, 2009 10:57 pm
Nice man.
I'll be gettin' this bar probably later hopefully.
Postby Akfahad » Sat Feb 21, 2009 1:55 am
again...what type y-pipe you running with that?
Postby Eye8Pussies » Sat Feb 21, 2009 3:50 am
great taking one for the team! glad to see that it all worked out and that it works as advertised.
give the measurements to adam when you can and if it it'll fit the gen3 as well, I'll probably pick one up too to get ready for track this summer and to protect my y-pipe lol
Postby Mr_Krispy1183 » Sat Feb 21, 2009 4:24 am
Akfahad wrote:again...what type y-pipe you running with that?
Sorry for the delay, stock y-pipe.
Users browsing this forum: Google [Bot] and 45 guests
