SolaraGuy.com • View topic - engine boggs/jerky during hard acceleration (NOW IT STALLS!)
Postby krook » Thu Jun 19, 2008 6:15 pm
the only way i can think of explaining this is that my engine..."boggs", i guess. for lack of a better word.
anyway, when i'm going up a hill, or accelerating hard, i can feel the engine studder a bit. i'm thinking maybe it's the spark plugs..? (changed during S/C install 60,000 mi or so ago)
any thoughts?
krook
Postby woa_its_j3ff » Thu Jun 19, 2008 6:45 pm
fuel injectors? check throttle body too.
mine has a similar situation roughyl 3 weeks back and I took off my intake, and cleaned my throttle body real good, and the problem went away.s imilar problem happened on my friends car and it turned out it was fuel injectors . so try both man, nto sure about that fuel injector one but i can speak for the t.b
Postby Eye8Pussies » Thu Jun 19, 2008 10:07 pm
well, since you're also boosted....what kind of gas are you putting in your car?
Postby SolaraBlue » Thu Jun 19, 2008 11:14 pm
had the same problem... twice! turned out to be the coil packs/spark plugs. im almost 100% sure, check it out.
Postby krook » Sat Jun 21, 2008 5:26 pm
woa_its_j3ff wrote:fuel injectors? check throttle body too.
okay, i'll check the TB first...btw, what do you guys clean it with?
Eye8Pussies wrote:well, since you're also boosted....what kind of gas are you putting in your car?
i only use the highest grade.
SolaraBlue wrote:had the same problem... twice! turned out to be the coil packs/spark plugs. im almost 100% sure, check it out.
crap, well i hope it's not those either but i'll check those last.
thanks for the input guys
krook
Postby krook » Wed Jul 02, 2008 2:40 pm
okay--the car actually STALLS now! i highly doubt it's the TB, or injectors at this point.
my dad thinks it's the fuel filter since he had the same problem.
does this sound familiar to anyone experiencing the same problem??
krook
Postby Eye8Pussies » Wed Jul 02, 2008 6:41 pm
quite possible
you're throwing no codes at all too, hm? that's tough....because it could either be not enough fuel or too much fuel
any smells?
Postby JavaJoe_2 » Wed Jul 02, 2008 6:59 pm
Pull the front spark plugs (60k) and take a look at them. Easy to get to, you can tell a lot.
Got Boost?? :sweet:
JavaJoe_2
Postby krook » Wed Jul 02, 2008 8:04 pm
Eye8Pussies wrote:quite possible
any smells?
naw, no codes...no smells.
what's weird is that if i shut off the engine and let it rest for a couple of minutes, it starts right up again. i'm noticing it dying out more frequently now when i gas it really hard. i'm talkin' i get about 10 meters at full throttle, and BOOM! dead.
krook
Postby krook » Wed Sep 10, 2008 3:07 pm
UPDATE:
i'm not sure if anyone had the same symptoms as i did (engine stall at WOT/going uphill) but i finally figured it out!
it turned out to be the BOOST ACTUATOR on my S/C. i replaced it for a mere 30 bucks after having troubleshooting other things and spending money on parts that otherwise were probably okay. (fuel filter/injectors)
krook
