SolaraGuy.com • View topic - clunking noise
clunking noise
clunking noise
Postby xh0rnsb0yx » Wed Mar 19, 2008 2:15 pm
hey so i have this weird noise coming from the trunk area i believe..
it was on the drivers side but then it kind of stopped and now i can hear it on the passengers side. i can hear it on the slightest little bump in the road and its starting to annoy the crap outa me..
i dont think its the struts and all of the spare tire stuff is in the right position.. so anyone know what this could be?
xh0rnsb0yx
Postby SleeperSolara » Wed Mar 19, 2008 2:53 pm
Do you have a TRD RSB??
Mine TRD RSB does that cause there isn't any grease on the poly bushin's holdin' the RSB.
Postby Ruski » Wed Mar 19, 2008 2:57 pm
to me its sounds like your top mount bolt . check that out .
Postby xh0rnsb0yx » Wed Mar 19, 2008 3:54 pm
na i dont have a rsb, whats a top mount bolt? and where would i find it thanks
xh0rnsb0yx
Postby ThatVietGuy » Wed Mar 19, 2008 6:17 pm
The bolt that holds the strut hat to the strut, all the way at the top buried beneath the rear deck/upholstery.
ThatVietGuy
Postby (K) » Wed Mar 19, 2008 7:44 pm
Might have bad strut mounts in general. Basically it's not your actual strut, but more of your strut assembly and all of it's "guts"...
(K)
Postby xh0rnsb0yx » Fri Mar 21, 2008 7:58 pm
dam that sounds like a hassle....ill have to wait for a free weekend to do that
xh0rnsb0yx
Postby TRAFFICBLOWS » Mon Mar 24, 2008 6:27 am
It could be your (stock) RSB bushings.
I had same problem when hitting bumps- got them replaced 2 mo ago and no more clunking.
99 Titanium SLE... 10-yr birthday Aug '08! She's slowly falling apart... :cry:
TRAFFICBLOWS
