SolaraGuy.com • View topic - PCV Valve change
PCV Valve change
PCV Valve change
Postby Dawgz » Mon Jun 18, 2007 12:43 pm
So if u want to replace the PCV valve, on a s\ced solara, do u HAVE to take off the s\c? or is there a trick to take it out?
Postby Paladin06Greg » Mon Jun 18, 2007 12:53 pm
No, you do not. It just takes a little knuckle busting and all real men know blood and oil go together real well.
Good luck 8)
Paladin06Greg
Torqued Solara
Torqued Solara
Postby Dawgz » Mon Jun 18, 2007 1:19 pm
hmm, its a really tight space Greg...i guess i gotta try with plyers? what do u use?
Postby Paladin06Greg » Mon Jun 18, 2007 1:26 pm
You got it my friend, pliers..
Paladin06Greg
Torqued Solara
Torqued Solara
Postby Dawgz » Mon Jun 18, 2007 1:32 pm
do u just wiggle it out or does it twist off?
looks like theres a rubber seal right under the pcv valve, theres gunk over it, im pretty sure some will fall in, so i better clean it off.
i think when i try to lift on it, itll touch the s\c, but yea. Thanx greg.
Twist off or pop off?
Postby Paladin06Greg » Mon Jun 18, 2007 1:54 pm
Just pops out. It is not threaded. It's tough but can be done. There is a clamp on the hose at the PCV also. It takes some work to free the clamp but, you can do it..
Dawgz wrote:do u just wiggle it out or does it twist off?
Paladin06Greg
Torqued Solara
Torqued Solara
Postby Astro » Mon Jun 18, 2007 5:25 pm
This is what I used:
Postby Dawgz » Mon Jun 18, 2007 7:36 pm
what is that plier called?
Postby Jon11582 » Mon Jun 18, 2007 7:43 pm
Bent-nose pliers. Yea, tool names are really creative.
2000 Black Solara SE
Jon11582
Postby Paladin06Greg » Mon Jun 18, 2007 8:35 pm
Correction, angled needle nosed pliers.
:lol:
Jon11582 wrote:Bent-nose pliers. Yea, tool names are really creative.
Paladin06Greg
Torqued Solara
Torqued Solara
Postby Jon11582 » Mon Jun 18, 2007 8:52 pm
Paladin06Greg wrote:Correction, angled needle nosed pliers.
:lol:
If you wanna be picky, its usually known as bent-nose needle-nose pliers or bent-end needle-nose pliers. Angled pliers usually refers to diagonal cutting pliers that have an angle on one side for easier cutting, but are actually straight-nosed.
See Here.
Another exciting episode of name-that-tool.
Jon11582
Postby Yanks0114 » Mon Jun 18, 2007 9:32 pm
:lol:
See Here.
Also called dykes :wink:
Postby Jon11582 » Mon Jun 18, 2007 9:46 pm
Yanks0114 wrote:
:lol:
See Here.
I searched google images for "dykes"...and lemme tell ya, thats NOT what I found :drinking:
Jon11582
Postby Dawgz » Wed Jul 25, 2007 2:45 pm
wow, what a bitch to remove, the hardest part was getting the faster/ring back around the hose to clamp the two together...its still not on correctly, i gotta go buy a slightly bigger ring.
my old one, barely rattles, the new one rattles freely.
the old one, u gotta actually try to get it to rattle.
