Throttle Body bypass?
Postby Dawgz » Thu Jun 14, 2007 9:49 am
http://cgi.ebay.com/ebaymotors/97-07-To ... 5093QQrdZ1
I heard of this elsewhere as well, has anyone done this mod?
--=Black on Black=--
241whp 215tq on DynoJet 424xLC2 (De-Supercharged on 7/3/10)
Postby Astro » Thu Jun 14, 2007 9:56 am
I did, but it doesn't do much. Others have told me you need it to keep the throttle body for getting extremely hot. Don't do it.
Postby Dawgz » Thu Jun 14, 2007 9:58 am
ok, cool, thanx.
Postby PDX SuperSolara » Thu Jun 14, 2007 3:38 pm
Bypassing the throttle body from coolant flow is something I wrote about several years ago and recommend because it does keep the intake stream a little cooler. But you don't need some lame kit. Just re-route the little hose from the lower intake back to the coolant flange below. It can't hurt unless you drive in very cold temps, way below freezing and even then, you just need to let the motor warm up for a couple minutes. I have been runnung this simple mod for 6 years with no bad effect, even at the lowest temps.
Jim @ Foreign Affairs
2315 SE 11th Avenue
Portland, Oregon 97214
503-236-2871
PDX SuperSolara
Postby 99V6solaraSE » Thu Jun 14, 2007 6:49 pm
is there a tutorial on this? if not there should be. Id like to give this a try.
99V6solaraSE
Postby Paladin06Greg » Thu Jun 14, 2007 7:03 pm
I've run it since 2004 without any issues..
Paladin06Greg
Torqued Solara
Torqued Solara
Postby CASTRO » Thu Jun 14, 2007 10:45 pm
same here, been running it this way 3 years strong
CASTRO
Postby Midias » Fri Jun 15, 2007 8:08 am
no tutorial needed if you spend a little money about 5 dollars get a 5/16 brass barb home depot plumbing isle and 2 hose clamps remove the lines and hook together.
Postby Fletch » Fri Jun 15, 2007 8:24 am
This topic comes up every couple years. My personal opinion is this mod does little to nothing for performance. My roommate and I both did this and switched it back for the winter.
I remember seeing a dyno chart of a LS1 before and after the TB bypass. It actually gained a few HP when the engine was still cool. No gains at normal operating temp.
Having said that, it won't hurt anything to give it a shot.
2006 Legacy GT spec.B
Fletch
Postby Midias » Fri Jun 15, 2007 8:25 am
here not same car but exactly same idea and same parts
http://timney.cz28.com/tbbypass.htm
If I do this later I will take pics
Postby Midias » Fri Jun 15, 2007 8:27 am
I did this on my accord as the New overbore TB was not able to accept the stock lines. I did not notice any read difference It may help in the hotter summer months but I am not sure.
Postby Eye8Pussies » Fri Jun 15, 2007 11:09 am
same as others- been doing it for years now with no problems.
better performance? no idea. but didn't hurt either, for sure.
And I'm sure when I had idling problems with my iac, not having hot coolant running through my throttlebody probably helped
Re: Throttle Body bypass
Postby 99V6solaraSE » Mon Jun 18, 2007 9:00 pm
PDX SuperSolara wrote:Bypassing the throttle body from coolant flow is something I wrote about several years ago and recommend because it does keep the intake stream a little cooler. But you don't need some lame kit. Just re-route the little hose from the lower intake back to the coolant flange below. It can't hurt unless you drive in very cold temps, way below freezing and even then, you just need to let the motor warm up for a couple minutes. I have been runnung this simple mod for 6 years with no bad effect, even at the lowest temps.
forgive me for my ignorance.. but im not exactly mechanically inclined lol
i havent quite located the coolant flange below...
and is the hose from the lower intake back, one of the hoses actually attached to the intake? so ill end up leaving one of the holes unplugged?
and btw i have a Cpe, so i guess itll look kinda different from the regular stock box.
99V6solaraSE
Postby Eye8Pussies » Mon Jun 18, 2007 9:59 pm
the coolant bypass hose will have nothing to do with the stock box
the coolant comes out of the block, into the place that it's run under the throttlebody, and then back out and back into the block.
all you have to do is disconnect the two rubber coolant hoses and get a dual male-ends adaptor and plug them together to make the coolant go in a circle back into the block
Users browsing this forum: No registered users and 0 guests
