SolaraGuy.com • View topic - FS: JL Audio 2 Chan AMP
Postby indiglosolara » Tue Sep 21, 2004 2:33 pm
JL Audio e2150 2 Channel Amp
This Amp was used to power my components in my Solara. The Amp is in good condition and never abused. Here are some specs of this amp:
Specifications: Rated Power (stereo), 45W RMS x 2 @ 4 ohm (12.5V);
75W RMS x 2 @ 2 ohm (12.5V) Rated Power (bridged)
90W RMS x 1 @ 8 ohm (12.5V) 150W RMS x 1 @ 4 ohm (12.5V) THD at Rated Power:
0.08% @ 4 ohm (20 Hz - 20 kHz)
S/N Ratio: 104 dB referred to rated power (A-weighted, 20 Hz – 20 kHz noise bandwidth)
Frequency Response: 10 Hz – 25 kHz (+0, -1dB)
Damping Factor: 200 @ 4 ohm per ch. / 50 Hz, 100 @ 2 ohm per ch. / 50 Hz
Slew Rate: ± 22V/µs
Input Range: 200mV – 8V RMS
Dimensions: 9.8" x 9.25" x 2.36"
Features: Absolute Symmetry™ Class AB Circuit (U.S. Patent #6,294,959)
Differential, Noise-Canceling Input Topology:
RCA jack inputs (low-level) and multi-pin jack (high-level)
On-board Crossover:
State-variable, 12dB/octave Butterworth with continuously variable cutoff frequency selection from 50 – 200 Hz. Configurable as Low-Pass or High-Pass
Preamp Output: Pass-through type.
Speaker output connections: accept up to 8 AWG wire
+12V and Ground connections: accept up to 4 AWG wire
Asking $150.00 Shipped or $140.00 Local pick up This will come with the Amp and original box and all instructions.
Im selling this because i bought a 4 chann instead to power my mids in the front and rear.
If you have any questions please email me at Kenny.ha@indymacbank.com or PM.
Thanks
Kenny
indiglosolara
Solara 2 xB
Solara 2 xB
Postby indiglosolara » Tue Sep 21, 2004 10:48 pm
indiglosolara
Solara 2 xB
Solara 2 xB
Postby indiglosolara » Wed Sep 22, 2004 5:48 pm
Bump!!!!!
indiglosolara
Solara 2 xB
Solara 2 xB
Postby indiglosolara » Thu Sep 23, 2004 6:47 pm
**SOLD**
bye bye amp
indiglosolara
Solara 2 xB
Solara 2 xB
