SolaraGuy.com • View topic - just a general subwoofer question
Talk about audio, video and nav installations and applications.
Postby wooshkie90 » Fri May 14, 2010 7:39 am
Okay so I have a single twelve in a ported box right now. only like 1.2 cu. ft. air space. Its a Kicker CVR12 and its on a kenwood kac-7204, givvin it about 400 watts kuz i hav it wired to 8ohm. My question is about the "hitting hard" part of it. I saw this box online that claims to add more power to my subwoofer just because it has 3 cu. ft. of air space. So do yall think 3 cu. ft. will make my 12 hit any harder than it does now?? any info will help greatly. thx.
Southern Cali does em best!
wooshkie90
Postby yoboyandre » Fri May 14, 2010 9:02 am
Usually increasing air size of box does give you a deeper bass, but the spec's for that sub suggest you don't go past like 2.25cu.ft. on a ported box so itll probably sound sloppy... if you want more bass you can wire your sub to 2ohms and you get the most bass.
yoboyandre
Postby Biggi_e » Fri May 14, 2010 10:55 am
go by what the specs are for the box.
Re: just a general subwoofer question
Postby TadS » Mon May 17, 2010 7:56 pm
As the others have said. Kicker has a spec for that sub. Maybe a little fiberfill in your current box, but stick to the spec.
TadS
Postby Down2TheC » Mon May 24, 2010 4:50 pm
Moved to audio
Down2TheC
Postby SoSleek » Thu May 27, 2010 10:29 am
To keep things VERY simple, you do not need a new box. You need a new amp. A mono amp that supplies 400x1 at 2ohm.
http://losangeles.craigslist.org/sgv/el ... 36519.html
Offer him $100 and let him counter, then ask him to meet you half way :) You'll get the amp for like $120, and be poundin.
SoSleek
Postby darrylsaladino » Tue Dec 21, 2010 12:21 am
I have been out of commision for about the past 6 years. My last monitors were Dyn BM15 passives with a Hafler. Thought about going BM6a but went with a gut feeling on the PMC's. Also had Dyn M1's before. Loved the Dyn's but I'm expecting the PMC's to really blow me away.
darrylsaladino
Postby SoSleek » Wed Dec 22, 2010 10:55 am
darrylsaladino wrote:I have been out of commision for about the past 6 years. My last monitors were Dyn BM15 passives with a Hafler. Thought about going BM6a but went with a gut feeling on the PMC's. Also had Dyn M1's before. Loved the Dyn's but I'm expecting the PMC's to really blow me away.
What?!?!
SoSleek
Postby 99BlackSandv6 » Mon Jan 31, 2011 5:43 pm
^^Spammmm!
Use the recommended box specs. And don't expect that CVR to pound like two twelves.
You'd be amazed at what a difference the right box, and right power will do for you.
Return to Audio/Video/Navigation
