SolaraGuy.com • View topic - Swaybar
Auto Flea Market.
Swaybar
Swaybar
Postby Solfan » Tue Aug 14, 2012 10:16 am
WTB: Rear anti-sway bar, TRD part no. PTR06-06990-10 for Gen 1 1999-2003 Solara. I know these have been discontinued from TRD for some time, just wondering if anyone happens to know a source that still has one in stock or if anyone has one for sale.
Thanks,
Glenn
Solfan
Re: Swaybar
Postby HARKEM » Thu Aug 16, 2012 2:21 am
I've got the following Whitline swaybars fitted and i think there awesome...i heard there just about to discontinue them so i would get them while you can...
FSB - BTF38
RSB - BTR39
http://www.whiteline.com.au/do_segue4.php?make=TOYOTA&model=CAMRY&model_final=CAMRY+%2F+VIENTA+SXV20R%2C+MCV20R+%28SCEPTER%2C+VISTA%29&vehicle=8%2F97-7%2F02
I've also got the Ultra racing Front lower strut brace(ebay) and fitted Superpro bushes(ebay) to my front control arms(just the rear bushes)
and overall it's really tight, controlable and corners alot better under power...just waiting on a tower brace..:)
2001 V6 CAMRY TOURING
DBA 4000 Slotted/Cross Drilled Rotors Front/Rear, EXEDY Stage 1 Race Clutch, FIDANZA 9lbs Flywheel,
Whiteline RSB & FSB, TRD Suspension, CUSTOM Headers&OBX CatBack, TRD S/C:)
HARKEM
Re: Swaybar
Postby Solfan » Sat Aug 18, 2012 8:08 am
Hey, thanks very much Harkem. I will try to get one on order.
Solfan
Re: Swaybar
Postby sliDingSolAra... » Sun Aug 26, 2012 11:28 am
someone posted a TRD rear sway in the 1.5 section if your still looking, but the whiteline above ^^^^ is awesome. not trying to send u away from harkem's deal just saying
02 5spd Engine scattered, working on a 3MZ S/C set-up
sliDingSolAra...
Re: Swaybar
Postby Solfan » Mon Sep 03, 2012 2:02 am
Thank you for the heads up, just got my Whiteline in the mail, though.
Solfan
Re: Swaybar
Postby adam2562 » Fri Sep 21, 2012 9:01 am
whiteline is amazing!! i had them on my Solara! handled like a Beaut!
Adam - 99 V6 5spd 165k -SOLD
adam2562
Re: Swaybar
Postby wiseman » Tue Jan 08, 2013 4:24 pm
With the whiteline rear do you have the stock strutbar or an aftermarket one? And if its stock does it handle ok or is it to stiff in the back and loose in the front?
wiseman
Re: Swaybar
Postby ThatVietGuy » Wed Jan 09, 2013 12:11 am
Whiteline rear sway with an OEM front strut tower bar is great. Lowered makes it even better.
ThatVietGuy
Re: Swaybar
Postby Gregtrd » Wed Jan 09, 2013 12:26 am
Here you go rear trd sway bar, trd strut bar and more....
viewtopic.php?f=3&t=54078
The Fastest Camry in Socal
366whp / 427wtq @10.5psi
Gregtrd
Return to Wanted/For Sale
