SolaraGuy.com • View topic - Questions about the Gauges.
Stock talk about Solara
Postby ChrissyD123 » Thu Dec 30, 2010 1:01 pm
Two of my gauge lights have gone out and I previously saw someone change the lighting on it. I would like to know how to even get in there...
Thank you!!
</SolaraGirl>
{15inch JL sub w/ 1000 JL Watt Amp.... Stock engine, but clean Lara}
ChrissyD123
Re: Questions about the Gauges.
Postby KILLA CAM » Thu Dec 30, 2010 2:42 pm
I'll help you out if you buy my blue gauge LEDs I'm selling... :P
I also have white LEDs. 8)
_________________________
Retired: Honda S2000
Current: E46 ZHP
KILLA CAM
Postby stringbean » Thu Dec 30, 2010 5:55 pm
Killa how much you want for the LED's? are the bulbs the same as in my 94 camry? if so ill take them, i wanna do the same thing.
stringbean
Postby KILLA CAM » Thu Dec 30, 2010 7:09 pm
stringbean wrote:Killa how much you want for the LED's? are the bulbs the same as in my 94 camry? if so ill take them, i wanna do the same thing.
The Gen4 uses five #194 bulbs. The Gen3 uses the same bulbs but I'm not sure how many. I bought them for $6 each from superbrightleds.com I'm selling them for $3 each. I have six of them. Let me know how many you want.
Current: E46 ZHP
KILLA CAM
Postby stringbean » Thu Dec 30, 2010 7:46 pm
thanks! ill take apart my dash and count them, i think its4 large bulbs and then some smaller one? if i remember correctly...
stringbean
Postby Mr_Krispy1183 » Fri Dec 31, 2010 9:29 am
Chrissy, there are a few Phillips head screws securing the cluster. Tilt the steering wheel if necessary to get a good angle. Once you remove the screws, you should be able to slide the cluster out. Just be wary of the accompanying wire harnesses/plugs still attached to the backside.
Postby stringbean » Mon Jan 10, 2011 6:26 pm
Ya so its 4 large 194 bulbs and a smaller one! can you post a pic of the led's if they are large and have multiple led's on them then ill take em! in white if you still got them!
stringbean
Return to Toyota Solara OEM
