SolaraGuy.com • View topic - cpe+nitrous??
For the one guy with it, and the few guys planning it...
cpe+nitrous??
cpe+nitrous??
Postby trd-cpe » Thu Aug 12, 2010 4:01 pm
i got 3.3 v6 3mz with cpe intake and trd exhuast!!
im putting the same nitrous system mike T's put but he has the injen intake i got cpe maf system so does anybody know if i might have a/f ratio problems or if it will throw cel's and what i can do to fix it...my cpe is untunable and the only other thing i have is trd exhuast.
coldfusion nitrous system
import wet kit single nozzle
gonna start with 35 bump it to 50
trd-cpe
Re: cpe+nitrous??
Postby corlon » Thu Aug 12, 2010 4:27 pm
got nitrous and cpe on my 1st gen v6. its a wet system, don't know what type mike t's is. no codes or issues with the 55hp shot.
NiCe
corlon
Re: cpe+nitrous??
Postby GzNutz » Fri Aug 13, 2010 9:39 pm
If you don't have a wideband, take it to a shop with a dyno and get it sniffed at wot. It's the only way to be sure your afr's are safe. Codes should not throw unless your afr's are way lean or too rich.
Re: cpe+nitrous??
Postby trd-cpe » Mon Aug 16, 2010 11:08 am
what about my ignition system??
did u change yours or have any issues??
trd-cpe
Re: cpe+nitrous??
Postby GzNutz » Mon Aug 16, 2010 2:21 pm
With only a 50 shot, ignition should not be an issue. Just run high octane fuel, 91+.
Re: cpe+nitrous??
Postby trd-cpe » Mon Aug 16, 2010 5:51 pm
Can i keep my plugs or do i need copper plugs. Its such a pain getting to the 3 bottom plugs so i would rather not if i dont have to.
trd-cpe
Re: cpe+nitrous??
Postby GzNutz » Mon Aug 16, 2010 6:22 pm
If you did anything with plugs you'd just want to go colder. But once again, a 50 shot won't give you problems so long as you're not running super lean or rich.
Re: cpe+nitrous??
Postby trd-cpe » Mon Aug 16, 2010 8:02 pm
Can i get away with 75 shot:)
trd-cpe
Return to Gen 2 Forced Induction
Users browsing this forum: No registered users and 2 guests
