SolaraGuy.com • View topic - camry differential
camry differential
camry differential
Postby guest » Mon Aug 26, 2002 10:26 pm
Hello Forum,
Does anyone know if the differential in the current solara is the same as in earlier cars with the V6 and 5spd tranny/ In particular the 93 V6LE Sport?
TIA Terje Salhus
guest
Re: camry differential
Postby Flipside909 » Tue Aug 27, 2002 9:16 am
guest wrote:Hello Forum,
TIA Terje Salhus
Differential? or are you asking about gear ratios? No, the gear ratios for the 5 speed 3VZ-FE V6 (92-93 Camry V6) is NOT the same as the 5spd 1MZ-FE (97-01 Camry/99-02 Solara).
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
camry differential
Postby tsalhus » Tue Aug 27, 2002 9:47 pm
I mean the differential itself. Quaife offers an ATB differential for the Solara and I was considering fitting one to my Camry if the differential carrier is the same.
Terje Salhus
tsalhus
Postby Flipside909 » Thu Aug 29, 2002 9:24 am
tsalhus wrote:I mean the differential itself. Quaife offers an ATB differential for the Solara and I was considering fitting one to my Camry if the differential carrier is the same.
Terje Salhus
Oh you mean a Limited Slip Differential? No they are not the same for the older models and the newer models. Totally different tranny.
www.clublexus.com
Flipside909
Postby Guest » Thu Aug 29, 2002 11:15 pm
:( Thanks for the info. Terje
Guest
Return to Toyota Camry
