SolaraGuy.com • View topic - 17.5 MPG with a 4cyl Camry
Postby Guest » Sat Nov 15, 2003 10:55 am
Hi, everyone
Just wondering is that possible?
Anyone ever experience that kind of a poor mileage out of their 4cyl Camry? ( My Camry is a 96 auto)
I filled up with BP Amoco (93octane) last week and only got 220 miles (slightly over a 1/4 of the tank left when I filled up again)
I do a lot of stop and go driving.
And I drive my car pretty hard sometimes.
Guest
Postby Jackass-Jeff » Sat Nov 15, 2003 11:44 am
It's possible to get really low milage from high reving and stop go driving.
Gas is eaten up the most when you start to move from a stop. Once you're already in motion, less effort is needed to accelerate because of your momentum. To save gas, you can try to cut down on revs (3000 max) and use a freeway. If you don't have an option to use the freeway, then your milage will only improve slightly from the 'gentle' driving
1GR-FE ftw!
Jackass-Jeff
Postby Yanks0114 » Sat Nov 15, 2003 1:18 pm
How old is your car? Any check engine lights? Is there anything else wrong with the car other than the mileage? and why are you using 93 octane, thats a waste for the 4cyl
Postby Mole » Sat Nov 15, 2003 1:21 pm
so if you were to go down to the E and have the reserve light come on, it would be roughly 300?
thats worse than my car.... i get 320-50
Postby Jackass-Jeff » Sat Nov 15, 2003 1:48 pm
Yanks0114 wrote:why are you using 93 octane, thats a waste for the 4cyl
False statement.
"that's a waste for a N/A LOW COMPRESSION engine" =] I'm sure the 3S needs some high octane stuff =]
1GR-FE ftw!
Jackass-Jeff
Postby Guest » Sat Nov 15, 2003 2:39 pm
I think the main reason why the mpg is so low, as many have stated before is because of the fact that I drive it hard. A friend of my, has an IS300 and he's kind of complaining that he get's 17mpg, but when I told him that I'm getting close to that he was very supprised. Not to mention the preformance of his car vs. mine which is very shity.
I don't know what you guys use in your 4cyls, but when I tried using 87 it ran like crap. 89 is acceptable I guess, but the difference in price is not that big between 89 and 93, so I tend to go with 93. Plus I have the feeling that the car runs smoother and has a bit more power.
As for the car itself it has 114k miles and no problems so far, it's very reliable. There seems to be nothing wrong with the car.
I'll try to take it easy on the next fill up and see what I get.
Guest
Postby SKYravefever » Sat Nov 15, 2003 4:24 pm
False statement.
False statement.
"I'm sure the 3S-GE or GTE needs some high octane stuff." =] There is the 3s-fe. ;)
And guest, register as a SolaraGuy member! We won't bite... and most importantly, we rarely flame :D Easy with that lead foot of yours, and your mileage should improve.
SKYravefever
Postby TadS » Sun Nov 16, 2003 1:07 am
I am pretty sure the 96 Camry is a 5S-FE guys. And stop and go driving kills my mileage too, just takes the motor alot of RPMs to the car moving. The 5S-FE is great for long distance freeway drives though.
TadS
Postby Yanks0114 » Sun Nov 16, 2003 2:06 pm
SKYravefever wrote:
False statement.
False statement.
I'm aware that certain 4cyl need 93 octane, but thats why i said THE 4cyl, refering to the camry 4cyl 5s-fe.
Postby Jai_Jai_Binks » Mon Nov 17, 2003 10:05 am
Guest - expect 220-250 for city driving (stop and go) and close to 300-350 for hwy driving...the thing is higer gears (m/t and auto as well) the car consumes less gas then it does in lower gears (stop and go situations). there are bunch of other stuff you could do if your mpg drop is unexplanable - change sparks, wires...get efi serviced, replace fuel-filter! but then again, like you someone else stated...that heavy rigth foot could ease up your milage as well....
Re: 17.5 MPG with a 4cyl Camry
Postby Kocho » Mon Nov 17, 2003 2:26 pm
Anonymous wrote:Hi, everyone
17 is kind of low, but not too far fetched if you torture the car in a city traffic. If you have poor mileage (less than 26-28 mpg on the highway, then I'd worry).
In my '00 i4 auto I usually put Mobil '93 (yes - it runs better, IMO compared to '87). On the highway I get at least 500 miles on the tank with less than a couple of galons left in it. This is between 30 and 33 mpg. I drive at about 65-80 mph, but usually do not come off overdirve almost at all.
In the city, I've never gotten below 23 mpg, it usually stays around 26mpg on mized city/suburban traffic. I do not push it too much, but still usually drive it more lively than most other grocery getters...
Kocho
Postby Turbosolara » Tue Nov 18, 2003 8:58 pm
it could be:
1. need to change engine oil?
2. Spark plug need to replace?
3. you car is running too rich (O2 sensor is dead) - check engine light might lite up
4. your tire pressure is not correct
5. you need wheel alightment
6. air filter need to replace
7. you have reallllly heavy objects in the trunk
Postby TadS » Wed Nov 19, 2003 2:53 am
UltraslowSolara wrote:it could be:
Need to stop hauling around all those bodies :lol:.
TadS
Postby Guest » Wed Nov 19, 2003 2:39 pm
it's none of the above :)
I changed the spark plugs and ignition cables when I was at 105k, now I'm at 114k.
Air Filter is clean, tire pressure is ok, no check engine light either.
I just have to take it easy on my Camry :wink:
I guess it's up to how you drive the car and not what you drive a 4cyl or V6. I need more low end torque :-?
Sorry that I still haven't registered at the site, had some problems with that, never got a return e-mail to confirm my registration :-?
Guest
Postby Hsakuragi » Wed Nov 19, 2003 3:15 pm
how HARD do you drive...i own a 95 5sfe camry before, usually i get 400 per tank with only octane 87...everyday i pull that car to 4500rpm on 2nd gear (auto) to get in the carpool lane, i still get that mileage.. total you get is 240-250 per pank? i remember 3rd gen camry has 14.5 gal tank..maybe ur gas tank is leaking?
Hsakuragi
Return to Toyota Camry
