SolaraGuy.com • View topic - 1MZFE backfires into the air intake
Postby carstenmeiner » Sun Aug 08, 2010 3:56 am
Hi guys.
When I rev my gen.4 V6 up to about 3600-3800 rpm it backfires into my Injen air intake. What can it be ? The sparkplugs ? Any suggestions ?
Carsten - Denmark.
carstenmeiner
Re: 1MZFE backfires into the air intake
Postby 99BlackSandv6 » Sun Aug 15, 2010 8:56 pm
Has the engine been apart and worked on recently?
When did it start backfiring?
Postby carstenmeiner » Mon Aug 16, 2010 7:15 am
99BlackSandv6 wrote:Has the engine been apart and worked on recently?
No it hasn't been apart or worked on recently.
I haven't used it for about 6 months and when I started using it again it backfired.
I have changed the sparkplugs and it has helped a lot but it still backfires when I rev it up to about 5000-5500 rpm
carstenmeiner
Postby 99BlackSandv6 » Mon Aug 16, 2010 7:37 am
Maybe because it sat for 6 months, the fuel has broken down.
Has the Check Engine Light come on?
If it ran fine when you parked it, it should run fine now.
Postby carstenmeiner » Mon Aug 16, 2010 7:41 am
99BlackSandv6 wrote:Maybe because it sat for 6 months, the fuel has broken down.
The fuel has been "changed" and the check engine light hasn't come on.
It ran fine when I parked it - no problems at all..
carstenmeiner
Postby 99BlackSandv6 » Mon Aug 16, 2010 8:03 am
Well, plugs and fuel are the most likely.
I guess you have taken care of both of those.
Maybe the problem will just fix itself.
Postby trentmeyer23 » Thu Aug 26, 2010 2:36 am
maybe a faulty inlet valve
trentmeyer23
Return to Toyota Camry
