SolaraGuy.com • View topic - need help identify this connector under the dash 1994 v6 cam
Postby lemegacool » Sat Jul 17, 2010 10:29 am
copy/paste from TN
hi!
well i'm about to do a 5 speed swap and i want to know what does this plug does? like is it a cruise control related plug that i should plug on the clutch switch?
its a 1 pin plug situated like right over where the clutch pedal should be... any ideas of whats the purpose of this plug?
thanks!
1994 camry v6 5 speed swapped
custom m90 blower in progress
cardomain: http://www.cardomain.com/ride/3872430
lemegacool
Re: need help identify this connector under the dash 1994 v6
Postby lemegacool » Thu Jul 29, 2010 8:56 pm
nevermind i found it... its P2 connector "parking brake switch" used with the pedal parking brake witch i dont have!
the cruise control clutch switch is connector C15... dont think i have this one since i have an auto harness... damn... now i need to find out what pin on the cruise ecu to use to jam my cruise clucth sw in...
lemegacool
Postby DSM_Lara » Fri Jul 30, 2010 3:30 am
Wow.. hears like your almost there? or just starting.... anyways good luck with the swap.
DSM_Lara
Postby lemegacool » Fri Jul 30, 2010 5:18 am
thanks!
i'm figuring out my wiring before i start putting thins in the car!
lemegacool
Return to Toyota Camry
