SolaraGuy.com • View topic - oil hanging on the passenger side front control arm
Postby JvR » Sun May 03, 2009 6:15 am
Yesterday i was looking at the exhaust system and I noticed oil hanging on the passenger side front control arm and the area around it.
It looks like engine oil. Anybody know what the leak is?
Thanks :party:
JvR
Postby Mole » Sun May 03, 2009 10:29 am
might not be oil, but cv boot leak.
Postby trd4life » Sun May 03, 2009 10:34 am
power steering rack
Postby JvR » Sun May 03, 2009 11:21 am
The color of de oil is blank (light yellow)
Almost the same color of new oil??
JvR
Postby carstenmeiner » Sun May 03, 2009 11:30 am
Like Gabe says it's the powersteering. I have the same problem :( You can get a rebuildkit for the powersteeringpump.
carstenmeiner
Postby JvR » Sun May 03, 2009 12:20 pm
on thing is funny, i checked every fluid and they are all full (brake, transmission,oil,coleant,etc.) :-?
JvR
Postby TRDSleeper » Mon May 04, 2009 7:22 pm
^ Yeap, I have the exact same problem. I was under my car when I noticed oil leaks in the same area as you described. When I took off the front wheel I saw that the power steering pump was covered in oil. My mechanic said it's a slow leak, nothing to be too concern about since the fluid level is still full. I would like to get the rebuild kit though. Does anyone know how much it costs and how difficult the job would be?
TRDSleeper
Postby samarai912912 » Tue May 05, 2009 4:19 pm
heres one. not a hard job to do at all. plus you can get in there and clean clean the crap out of it. might as well replace the belt also. powersteering fluid is bad for other components.
ebay oem toyota rebuild kit:
http://cgi.ebay.com/ebaymotors/TOYOTA-4 ... ccessories
samarai912912
Postby GreeKAvaLoN » Tue May 05, 2009 8:30 pm
^one bigass sig. Are you sure its not your CV boot leaking or squirting out grease? Mine is horribly and its EVERYWHERE so maybe look around your rims too. Just a thought =P goodluck!
GreeKAvaLoN
Postby jetbtkng » Tue May 05, 2009 9:52 pm
samarai912912 wrote:heres one. not a hard job to do at all. plus you can get in there and clean clean the crap out of it. might as well replace the belt also. powersteering fluid is bad for other components.
those rims look familiar, Image
Return to Toyota Camry
