SolaraGuy.com • View topic - 2002 camry headlight housing
Postby jbn19431938 » Tue Nov 02, 2004 1:00 pm
Just embarassingly bashed, but only slghtly, wife's Camry's front right bumper. Can deal with repainting abrasions on bumper, but fender just above bumper is bent back slightly. Looks as if it would push out easily if I could get behind it, but plastic headlight housing is in way. How do I remove/replace housing to get at inside of fender surface?
jbn19431938
Postby Duffman » Tue Nov 02, 2004 1:02 pm
Your best bet would be to remove the entire headlight assembly (which might be what you're hinting at, not sure - have pics?). That's usually a combination of screws and bolts, try looking around it. Or, post some pics and we'll see if there's any noticeable way.
2005 Pontiac GTO 6-Speed
2008 Suzuki Bandit 1250 ABS
Duffman
Postby jbn19431938 » Thu Nov 04, 2004 11:37 am
Duffman wrote:Your best bet would be to remove the entire headlight assembly (which might be what you're hinting at, not sure - have pics?). That's usually a combination of screws and bolts, try looking around it. Or, post some pics and we'll see if there's any noticeable way.
Yeah, that's what I need, some pics or whatever of how to remove headlight assembly. Any ideas? I feel so stupid asking how to do what I thot should be a simple task!
tyvm for ANY help!
jbn19431938
Postby mighty~mart » Thu Nov 04, 2004 11:58 am
need to remove front bumper first... supposedly its easy to find the bolts if you look around.
although i have yet to do this.
will let you know if i accomplish this.
SMARTin
Camry Gen 5 SE I4
mighty~mart
Postby jbn19431938 » Sat Nov 06, 2004 7:31 pm
You're kidding!
Remove front bumper to remove headlight housing?
How easy can it get? (gentle sarcasm)
jbn19431938
Postby Duffman » Tue Nov 09, 2004 8:18 am
It's more common than you think... the 1965 Riviera had its lights in the rear bumper and you had to remove the entire bumper to change a bulb.
They don't usually consider the headlight housing to be something most people don't remove. Expect it to be a hassle.
Duffman
Postby bronzemaxell » Wed Nov 10, 2004 8:37 pm
jbn19431938 wrote:You're kidding!
i think there are bolts you need to loose from inside the fender through wheel well beside the ones on top, and it will come right off.
bronzemaxell
Return to Toyota Camry
