SolaraGuy.com • View topic - WANTED WHEEL SPACERS 15 or 20mm - I have 25mm to trade
Postby Joe Cat » Sun Nov 29, 2009 11:31 am
WANTED WHEEL SPACERS 15 or 20mm - I have 25mm to trade or buy outright
I have mmr hr3 18's 42 off set
I also have a lexus ls430 which is the same bolt pattern so i tried a tire that would work for both cars- Not into that rubber band look-
225-55-18 and the rears rub the lower shock tower any suggestions!!!
I have a 25 mm spacer and then it rubs the outer fender, then i had a 10mm spacer
now it doesnt rub the fender but the lower shock tower -
Question if i lower the air pressure in the tire---aahhh what a stuopid question just typing it sounds stupid-----NOw What??
new Tires I guess!
Joe Cat
Postby t3chnique » Sun Nov 29, 2009 3:01 pm
i think you need some 225/45 (or 50)/18 tires...
t3chnique
Postby kingkakyle » Sun Nov 29, 2009 3:55 pm
t3chnique wrote:i think you need some 225/45 (or 50)/18 tires...
yes to be closest to stock diameter would be 225/45 on 18s on a gen 2
Postby 99BlackSandv6 » Sun Nov 29, 2009 5:42 pm
Too much tire.
Re: WANTED WHEEL SPACERS 15 or 20mm - I have 25mm to tra
Postby ADAMnQuickSOLARA » Wed Feb 03, 2010 2:53 pm
how much? 2 or 4? are they hubcentric? pic? thanks
Joe Cat wrote:WANTED WHEEL SPACERS 15 or 20mm - I have 25mm to trade or buy outright
new Tires I guess!
ADAMnQuickSOLARA
