SolaraGuy.com • View topic - Headunit Help
Headunit Help
Headunit Help
Postby KoZ-44 » Sun May 09, 2010 6:56 pm
Hey guys
I was messing around with my amp today and accidentally shorted something. Now my head unit won't boot up yet the light flashes. I'm pretty sure I blew a fuse but I looked and didn't see anything blown. Any ideas what this might be and what fuses I should double check?
Thanks
Kyle
[img]http://img690.imageshack.us/img690/9258/img0458u.jpg[/img]
KoZ-44
Postby KoZ-44 » Tue May 11, 2010 8:58 pm
Seriously? No help what so ever? Basically I am just asking what Fuse is for the radio and where is it at on the panel. FYI I'm 6'6 so its a bit uncomfortable to try and get under the drivers side panel to remove and check the fuses. Also the shop quoted me $40 to do a diagnosis on my head unit, when in reality all they are really doing is replacing a $.60 fuse... Assholes..
Thanks guys
KoZ-44
Postby Aotoyota » Tue May 11, 2010 9:12 pm
slow down cowboy..
have you pulled the headunit? there is usually a fuse on the radio or on the harness. try that first.
also is the rest of the car ok?lights turn signals etc.
does the amp turn on?
Aotoyota
Postby KoZ-44 » Tue May 11, 2010 9:42 pm
haha sorry.. still hyped up on coffee from finals and getting very irritated with using my droid as my cars music source
Ive pulled the unit out and the fuse isn't blown.
The amp turns on and everything else seems to be okay..
KoZ-44
Postby Aotoyota » Tue May 11, 2010 10:17 pm
do you get sound? and what type of amp 4 ch? mono for a sub?
model of the radio too?
Aotoyota
Postby KoZ-44 » Tue May 11, 2010 10:38 pm
I got a Kenwood DDX512 Touch-Screen Headunit
Rockford Fosgate P400.4 running my highs and lows
bridged to a Alpine M450
powering 2 JL 10W0
No the headunit wont turn on. there is power running through it but it wont turn on
KoZ-44
Postby TLMNICK » Tue May 11, 2010 11:00 pm
Hit the little reset button on the face of the deck. Sometimes those decks get confused and do strange things like what you're experiencing. You'll need to use a pen or something to press it, since it's a super small button. I used to have that deck in my maxima.
IF the "light that flashes" is the little red one in the top left corner, then you've blown a fuse in the car, and you need to change it. That little red light should only "flash" when the key is out...once the key is in the ignition and turned on, it should stay lit constantly. Don't forget to check the fuses under the hood too....and check ALL of them, not necessarily just ones related to "radio".
TLMNICK
Postby KoZ-44 » Tue May 11, 2010 11:23 pm
thanks a bunch man.. I'll do that tomorrow
KoZ-44
Re: Headunit Help
Postby NightRider » Sat May 22, 2010 5:09 pm
So I guess it's fixed? Cause he hasn't came back to post.
2004 Black Solara V6SLE COUPE
Injen polished SRI
TRD FSB 6000K HID's
NightRider
Re: Headunit Help
Postby KoZ-44 » Sat May 22, 2010 10:04 pm
Sorry! Yes it is fixed. Replaced a couple of fuses and I was good to go.
KoZ-44
Return to A/V/N Gen 2 and 2.5
Users browsing this forum: No registered users and 2 guests
