SolaraGuy.com • View topic - Removing trunk paneling and folddown seat barrier
Postby MalBandito99 » Wed Sep 24, 2003 1:21 pm
Hey, I got a little dilemna. Ordered a subwoofer box built to specifications for maximum size; it'll fit once its in, but I can't just slide it in through the normal trunk opening. I think I'll need to do it from the inside, thus I need to clear some room so I can get this 41"x16"x14" sub box in. How do I remove the rearfold down seat barrier to the trunk, if at all possible?
Please help me. I'm so frustrated that I finally got my stuff here and it won't fit in normally. Thanks.
MalBandito99
Postby Peter » Wed Sep 24, 2003 1:26 pm
under the carpet there's bolts. really easy, just look around. fold down the chairs and lift the carpet close to the pivot point of the chairs. good luck and let us know how it goes
Peter's "Black Sheep"
Visit Black Sheep
Peter
Postby HKSV6SLE » Wed Sep 24, 2003 1:50 pm
what size subs are going in? that sounds like a huge box....i took my box out of my trunk while my amp is getting fixed and my car went up half an inch in the back...
2008 LEXUS IS350 SGM
www.lexusnet.com
HKSV6SLE
Postby Guest » Wed Sep 24, 2003 1:52 pm
Thanks for the advice. Any more help from an other experienced people would be great too. I just took off the clips from the inside in the rearfold seat barrier to the trunk, but theres metal supports on the inside. Any help would be greatly appreciated. Thanks again.
Guest
Postby MalBandito99 » Wed Sep 24, 2003 1:54 pm
Oh its just one 12. :D RE 12XXX sub, feeded 1400wrms at 1 ohm. The box is one hell of rat maze as far as vents go.
MalBandito99
Postby MalBandito99 » Wed Sep 24, 2003 5:18 pm
Ahha, eureka! Got the enclosure in by much hard and painstaking thinking. Got the taillight trunk panel removed, which gave enough room to squeeze the corner of the box in, and then it works! Thanks for the help anyways guys! Once I get the sub installed, I'll post some finished pics for yall. 8)
MalBandito99
