SolaraGuy.com • View topic - advice/help on wiring
Postby wooshkie90 » Sat Nov 07, 2009 7:22 pm
I just got done wiring the car for when the amp gets here, but i ran into a problem with the remote wire. I have a JVC KD-G120 head unit, but the remote wire coming from it has what looks like a fuse holder looking connection on it. Do you thing its safe to just cut it off and run it straight to the amp?? any advice helps.
wooshkie90
Postby Ruski » Sat Nov 07, 2009 7:39 pm
what color is the wire ?
Postby wooshkie90 » Sat Nov 07, 2009 8:10 pm
its blue with a white line. the diagram on the head unit says its the remote wire. it says 200 mA max on the wire, if its any importance
wooshkie90
Postby Ruski » Sat Nov 07, 2009 10:03 pm
hmm i never had any fuse holder on my remote wire. you can use a different source for remote turn on for the amp . any 12v source like a cig lighter will do same thing
fuse
Postby NRDriver » Sun Nov 08, 2009 4:54 am
why dont you want to use it just cuz it haz a fuse?
NRDriver
Postby wooshkie90 » Sun Nov 08, 2009 7:28 am
My intentions are definitely to use the remote wire from the head unit, hwever, i just wanted advice on it before I do something. Ive never done it before and i dont want to ruin the remote wire. but hey, if yall are sayin it wont hurt, ima go adead and do it.
wooshkie90
Postby Ruski » Sun Nov 08, 2009 8:05 am
go for it man. i just cant relate i never had a fuse on my remote wires
Postby 99BlackSandv6 » Sun Nov 08, 2009 9:11 am
Yeah, it should be fine.
Mine doesn't have a fuse, I think the idea is just
for a little extra protection.
Postby MisterTedster » Thu Nov 12, 2009 8:35 pm
Yes, just wire it. I believe the fuse is for the occassional power surge that can run through a remote wire, leading to that dreaded subwoofer 'pop' that can destroy many subwoofers that can occur even if your amps have soft turn-on. The manufacturer probably added the fuse to prevent people from accidentally blowing their subs by just having a fuse that can blow out instead.
MisterTedster
