SolaraGuy.com • View topic - okay one more question
Postby wooshkie90 » Wed Oct 21, 2009 6:40 pm
A fellow sg'er enlightened me on my subwoofer and amp situation. Just wanted to know if there are any alternate ways of wiring my setup to get all 600 watts from my amp to my sub?? heres my setup. thx for any input.
Amp-
Item Description:
2 Channel Amplification
300 Watts x 2 Output
600 Watts x 1 Bridged Output
Fully Adjustable Electronic Crossover Network
Variable Bass Boost (0-12dB @ 60Hz)
Soft Turn On/Off Circuit
2 Ohm Stereo Stable
Bridgeable into 4 Ohms
MOSFET PWM Power Supply
Heavy Duty Aluminum Alloy Heatsink
Discrete Wire Connections
Variable Gain Control
Remote Turn On/Off
Hi/Lo Gold Plated MOLEX Level Inputs
Power On LED Indicator
LED Protection Indicator
S/N Ratio: >95dB
THD: <0.04%
Frequency Response: 20-30kHz
Thermal/Overload/Short Circuit Protection
Dimensions: 8.''L x 2.25''H x 10.25''W
Subwoofer-
NTX-6612
12” Dual Voice Coil Subwoofer
•Diameter - 12”
•Max Power - 600W
•Sensitivity - 89.8dB
•Frequency Response - 28Hz~600Hz
COMMON FEATURES:
•Super LED Light Effects
•Aluminum Brush Injection Cone
•Large Heavy Duty Magnet Structure
•Protective Rubber Magnet Ring
•Black Push Type Terminals
•2-4-8 Ohm Connection
•Dual Voice Coil
PLz help!!
wooshkie90
Postby Aotoyota » Wed Oct 21, 2009 9:35 pm
bridge the amp and connect the sub in parallel so its a 2ohm load.
both manuals should say how to.. gl!
Aotoyota
Postby Ruski » Wed Oct 21, 2009 10:17 pm
^ I agree. the sub should have a diagram on how to wire it and so should the amp.
Postby corlon » Wed Oct 21, 2009 10:34 pm
the amp is not bridgable to 2 ohms. if the woofer is a dual 2 ohm then series the connections on the woofer to 4 ohms. that will give you the most output from your amplifier.
NiCe
corlon
Postby GreenSolara01 » Thu Oct 22, 2009 8:21 pm
corlon wrote:the amp is not bridgable to 2 ohms. if the woofer is a dual 2 ohm then series the connections on the woofer to 4 ohms. that will give you the most output from your amplifier.
X2
GreenSolara01
Postby GreenSolara01 » Thu Oct 22, 2009 8:32 pm
I'. not sure what the voice coils are rated at but either way one of these will help. Don't run a 4ohm stable amp a 2 it will fry. Its more a voltage stability thing tou can run it at one ohm but once you hit some bass and your cars voltage dips, poof.
GreenSolara01
Postby SoSleek » Mon Oct 26, 2009 7:40 am
I don't know why you started this thread. I have posted all of the info you need on your other thread. Your ONLY SAFE option is to run like this...
SoSleek
