SolaraGuy.com • View topic - bridging 4 channel amp
Postby dkertis10 » Tue Jul 28, 2009 12:13 am
i have a kicker zx350.4 that puts out 60rms x4 at 4 ohm. it sounds good but i want it louder because hearing aids aren't expensive anymore. my new door speakres can handle 200rms at 4 ohm so i'm going to bridge it to 2 channels which makes 175rms x2 at 4 ohm. the question i have is when i bridge it, can i still power my rear speakers off the amp? i only want the fronts to get the 175 but i dont just want no sound in the rear and i don't want those to blow
Kicker sound system, 17 inch MB Wheels on Continental ContiExtremeContact tires, more mods to come..
dkertis10
Postby jimmm » Tue Jul 28, 2009 4:22 am
What did you say? :D
jimmm
Postby D-money » Tue Jul 28, 2009 10:12 am
nope, when you bridge it you cut out two channels
D-money
Postby ~SolaRaSpeed~ » Tue Jul 28, 2009 10:33 am
you can use the headunit to power the rear speakers, since with that much power going to your fronts they are going to be rear fill anyways. by the way are your front speakers components and running through a crossover, because if they are then you should consider some active EQ'ing instead.
~SolaRaSpeed~
Users browsing this forum: Google [Bot] and 43 guests
