SolaraGuy.com • View topic - Remove center panel
Remove center panel
Remove center panel
Postby vSolara » Tue Mar 10, 2009 11:26 am
Hi, I'm trying to remove the black center panel so I can get to the radio. I took the ash tray out and I pulled out and got the two bottom clips undone. However I'm pulling and pulling but I cant get the rest of the clips undone. What areas should I be pulling from?
Thanks
2001 Toyota Solara SLE V6 - Tinted Windows, Pioneer DEH-2100IB, Pioneer Door Speakers, Custom DIN voltmeter/switchboard, interior accent LED strips
vSolara
Postby D-money » Tue Mar 10, 2009 11:35 am
what i did was point both center vents down that creats a lip below them pinch that lip with both hands and give a quick tug or two if done right the entire pannel will pop loose let me know if you have any more questions
D-money
Postby ~SolaRaSpeed~ » Fri May 15, 2009 10:53 pm
either that or tape up a flathead screwdriver and push it between the top of the trim panel and the dash and push slowly
~SolaRaSpeed~
