digital capacitors???
im redoing the system in my car and i would like to know at what point should i install a digital capacitor? a
- AguinaldoHomes Inc
- Regular SolaraGuy Member
AguinaldoHomes Inc wrote:oh one more thing, will i be able to custom mount a set of component tweeters onthe pillar(right where the driver/passenger seatbelt is)?
Astro wrote:Try making a custom kick pod and mounting your mid and tweed there, rather than putting your tweed on the pillar. Another alternative is putting your tweed on the pillar but face it toward the windshield. By reflecting your highs off the windshield it won't be overly bright.
AguinaldoHomes Inc wrote:Also, is there anything I can do to rid of or at least control the "rattling" of the trunk when the subs are pumping? I just want a clean bass if possible.
theprodigy79 wrote:Not sure whether you're asking when to install a digi-cap vs a "standard" cap, or when to use a cap at all... The only difference between a "digital capacitor" vs a "normal" one is the digi-caps have a voltage readout... Otherwise they function exactly the same. Keep that in mind...
First off, don't fall into the "capacaitor cures all" myth... The most common misperception about capacitors is that they are intended to cure dimming headlamps and internal lights and maintain a constant power level...
While those are certainly side effects AT TIMES, they are not the intent of the capacitor, and often not results of adding one... Capacitors are actually intended to prevent power spikes and dips from reaching your electronic equipment, and also to protect your electrical system (alternator, battery, etc...). They do NOT maintain or regulate power, as even the larger ones can only fend off a substantial fluctuation for a matter of miliseconds.
With all that said, the best thing you can possibly do for performance are the "big three". Depending on the power you plan to run, I doubt you'll have to touch your alternator, however I certainly advise upgrading your battery, power and ground wires. Doing those couple, relatively cheap/easy things will make immense differences in performance and will usually cure most, if not all dimming!!
From there, add the capacitor... The rule of thumb is 1 Farad per 1 kilowatt (.5 Farad to 500 Watts)... I find that number to be rediculously low, and would personally advise at least 2 Farad per 1 KW (I used a 5 Farad cap for my 2000W RMS system).
Follow those steps and you'll be very well off. If you're running a substantial amount of power (over 1.5KW RMS) I'd advise looking into upgrading the alternator (the third of the "big three") before you add the cap.
james you have a sick ass system my man, i checked out your sounddomain joun. id love to see that in person sometime over winterbreak bud.
-steve
If it means anything at all, I'm currently running around 500-600W RMS in my Supra and not using a cap. My results have been fine.
Take care,
-James
AguinaldoHomes Inc wrote:Here's my set up:
Kenwood KFC-P707 6.5" Front Component Speakers (65w/280w)
Kenwood KFC-6990ie 6x9 Rear Speakers (80w/350W)
Kenwood T-207 Component Tweeters (130w/280w)
Pair of Kenwood KFC-W3514DVC 12" Subs (380w/1500w)
Kenwood KAC-9103D Mono Amp
Kenwood KAC-8403 4/3/2 Channel Amp
Kenwood DDX-7019 DVD/TV/CD Receiver
Any suggestions would help.
