SolaraGuy.com • View topic - WTF?? my system!!
WTF?? my system!!
WTF?? my system!!
Postby whiteflash » Sun Dec 05, 2004 6:18 pm
k guys so u know my setup i have two amps a cap in the middle one amp to my speakers one amp to my sub anywya the other day i was driving and some lady stopped short so i stopped short too all of sudden the musci isnt comin out of the speakers anymore but the radio is still working and all, so i get home pop the trunk and i notice that i braked so hard that the negative wire got ripped out and went over and touche the power wire andwya they were like melted together only at the wire part so i clipped each end redid it and now i sitll ahve no sound in my speakers all the fuses are good i took out my sub and my cap so the poweer wire went straight to the amp for the speakers but it doesnt make sense could it jsut be that it messed up the wire without messing up all the fuses even the fuse near the battery?
Injen w/CAI Extension
Vogtland Springs
Tokico Struts
Custom Full exhaust
TWM Shortshiftter
8000K HID Kit
whiteflash
Re: WTF?? my system!!
Postby Mole » Sun Dec 05, 2004 6:31 pm
whiteflash wrote:k guys so u know my setup i have two amps a cap in the middle one amp to my speakers one amp to my sub anywya the other day i was driving and some lady stopped short so i stopped short too all of sudden the musci isnt comin out of the speakers anymore but the radio is still working and all, so i get home pop the trunk and i notice that i braked so hard that the negative wire got ripped out and went over and touche the power wire andwya they were like melted together only at the wire part so i clipped each end redid it and now i sitll ahve no sound in my speakers all the fuses are good i took out my sub and my cap so the poweer wire went straight to the amp for the speakers but it doesnt make sense could it jsut be that it messed up the wire without messing up all the fuses even the fuse near the battery?
jesus kid.
youshouldlearnhowtouseparagraphsandcorrectgrammarbecauseitgetshardtoread
there is a good chance that your amp blew due to the shock. not to mention other difficulties.
Postby whiteflash » Mon Dec 06, 2004 12:33 am
sorry bout the long paragraph tomm ill try a new amp but it doesnt seem like the wire is even suppling power could it be that when it happened it jsut went through the whole wire
Vogtland Springs
Tokico Struts
Custom Full exhaust
TWM Shortshiftter
8000K HID Kit
whiteflash
Postby geminimouse » Mon Dec 06, 2004 9:53 am
When something like this happens...most of the fuses should be blown....the wires can't be damaged
unless ur fuses somehow didn't blow like they were suppose to and blew ur amp...
08 Accord Coupe
99 Solara Sold on 7/7/07
geminimouse
Postby Parke10 » Mon Dec 06, 2004 11:36 am
if your speakers dont work meaning yer radio doesnt...? if so did u check the stock ones under the dash?
Parke10
Postby cdeez » Mon Dec 06, 2004 11:39 am
^^^lol...dude that was funny mike. ^^^
yeah, check all fuses, and make sure you amp light is on. if your amp light is on then you know there is power there and the problem maybe somewhere else.
last standing...
Socalara...
cdeez
Postby Jackass-Jeff » Mon Dec 06, 2004 11:47 am
"YOU GOT OWNED"
You created a short circuit when the POS and NEG wires touched and both were on the POS terminal of your amp... Your amp should be ok. The amp won't power on w/o being grounded, so that is why the fuses didn't blow. The POS was being grounded when it touched and fused w/ the NEG cable. Long story short:
Buy a new amp, I'm sure the one you had was a pos anyway =P
Logically, the amp should be ok... unless the fuses in the amp were "Just for show" and didn't really function! lol
1GR-FE ftw!
Jackass-Jeff
Postby whiteflash » Mon Dec 06, 2004 4:01 pm
the radio is on it turns the station and displays everything just that the first amp to the speakers will not turn on
Vogtland Springs
Tokico Struts
Custom Full exhaust
TWM Shortshiftter
8000K HID Kit
whiteflash
Postby indiglosolara » Mon Dec 06, 2004 5:50 pm
whiteflash wrote:the radio is on it turns the station and displays everything just that the first amp to the speakers will not turn on
Uhh... check your fuses.. Or better yet just replace the fuses. Cuz i have a fuse blow before and the fuse doesn't look broken but it wasn't supplying power. Use a Volt meter and test the wires to be sure its getting 12V+.
or what Jeff Said, Just buy a new Amp..
indiglosolara
Solara 2 xB
Solara 2 xB
Postby whiteflash » Mon Dec 06, 2004 6:25 pm
if the fuses was bad why would the radio turn on
Vogtland Springs
Tokico Struts
Custom Full exhaust
TWM Shortshiftter
8000K HID Kit
whiteflash
Postby geminimouse » Mon Dec 06, 2004 6:46 pm
whiteflash wrote:if the fuses was bad why would the radio turn on
Fuse for the radio isn't the same as ur amp
08 Accord Coupe
geminimouse
Postby Jackass-Jeff » Mon Dec 06, 2004 6:47 pm
OH!?!
THe RADIO can be heard throught he speakers but CDs cant? Is that what you mean?
If not, then you probably havent checked the fuses that are BUILT INTO THE AMP. I hope you don't just mean your single power fuse =P Check all your fuses! If anything, the AMP fuses blew, not the one from the battery. THe fuse from the battery will blow if a battery sends a big jolt. The fuses in the amp will blow if your stuff short circuited. It's the AMP FUSES, not the main power fuse...
Good Game Fuses.
1GR-FE ftw!
Jackass-Jeff
Postby whiteflash » Mon Dec 06, 2004 10:26 pm
both fuses in the amp are perfect i checked those first and no by saying the radio works i mean the head unit works it lights up u know does wat its suppose to except nothing comes out the speakers becasue it has to get through the amp first
Vogtland Springs
Tokico Struts
Custom Full exhaust
TWM Shortshiftter
8000K HID Kit
whiteflash
Postby indiglosolara » Mon Dec 06, 2004 11:09 pm
whiteflash wrote:both fuses in the amp are perfect i checked those first and no by saying the radio works i mean the head unit works it lights up u know does wat its suppose to except nothing comes out the speakers becasue it has to get through the amp first
check you inline fuse from your amp wire from the batt.
indiglosolara
Solara 2 xB
Solara 2 xB
Postby whiteflash » Mon Dec 06, 2004 11:39 pm
i checked the fuse thats between the batt and the amp its perfect tooo
Vogtland Springs
Tokico Struts
Custom Full exhaust
TWM Shortshiftter
8000K HID Kit
whiteflash
