SolaraGuy.com • View topic - 2 12'' kicker L7 or 1 13.5'' JL W7
which would hit harder???
2 12'' kicker L7
8
73%
1 13.5'' W7
3
27%
Total votes : 11
Postby chinaxb0y » Mon Nov 29, 2004 10:17 pm
i need your people's opinion. i want something that hits harder than what i have right now so i was wondering what would be good. i'm thinking of these 2 subs. which one u guys think would hit harder. the 2 L7's or the 1 W7.
post in the correct forums
chinaxb0y
Subs
Postby SolaraGuy22 » Mon Nov 29, 2004 10:25 pm
I'm not sure about the 13.5 but I know that the L7's will POUND loud as all hell. I am installing 2 10w7's when I figure out my enclosure I want. They've just been sitting here. I will let you know how that turns out.
-Anthony
SolaraGuy22
SolaraGuy Pimp
SolaraGuy Pimp
Postby krawzyazn » Tue Nov 30, 2004 1:39 am
kicker all the way lol I got some for sale too :drinking: :lol: :drinking:
Re: 2 12'' kicker L7 or 1 13.5'' JL W7
Postby pro956 » Tue Nov 30, 2004 8:30 am
chinaxb0y wrote:i need your people's opinion. i want something that hits harder than what i have right now so i was wondering what would be good. i'm thinking of these 2 subs. which one u guys think would hit harder. the 2 L7's or the 1 W7.
2 L7s...
a 12w7 can be louder than a 12" l7
so a 13w7 can definately be louder than a 12" l7
but 2 12" l7s... that's a lot of surface area that almost all single 15" setups would have trouble beating
the excursion would have to be pretty insane...
AIM: pro956
2002 5-speed se v6
pro956
Postby WortownSolara » Tue Nov 30, 2004 9:14 am
for them both too sound right you will need an enormous amount of power, being fairly level, 1500rms is about right, you really want to have some "head room" (extra power) for theses behemoths. They will need it when dropping low. Your biggest issue is going to be the power supplied by the car may limit you too some extent of volume. My suggestion would be to get a batcap 400 and a supercap. They should hold you off for the REALLY loud hits. But an alternator is always wise. The L7's will be alot louder, the cone surface of the L7's are quite larger than the one 13.5 JL.
If it doesn't kill you.....it only makes you faster!
WortownSolara
Audio Guru
Audio Guru
Postby SleeperSolara » Tue Nov 30, 2004 9:35 am
Yeah man go wit Kicker.
My friend has 2 Kicker 12" L7's and they are mounted in a ported box, he runnin' almost 1400 watts. :o
And those hit so hard you can hear him a block away.
If you get the Kicker wit a ported box................. becareful cause it will tear apart your trunk. :o
No i'm just playin'; but the Kickers are the best.
I have a 10" L5 at home wit a ported box, and that hits pretty good.
Now i just need to make a better ported box. [ Like fiberglass or pexiglass]
Postby B_Master_Flash » Tue Nov 30, 2004 3:50 pm
really no contest... For some reason ppl think that b/c w7s are expensive they will somehow be incredibly loud for their size. They aren't an spl sub, they are a sq sub that just gets loud. The L7s are straight SPL, w/ little sq. Over all I would recommend the w7 if you have the money, put it in a ported box w/ 1000wrms and it should be pleny loud w/ much better sound quality. Also check out Resonant engineering XXX or SX, Adire Audio Brahma, Inciminator Audio Death Penalty, and Orion H2, all great subs that get loud. (might want to check out Digital Designs if you have the $$)
B_Master_Flash
Postby MalBandito99 » Wed Dec 01, 2004 6:43 am
If you find a correct way to modding the solaras electrical in a cost economic way so you can get atleast 1500 wrms out of the alt., let me know cause my 1400 wrms amp is only putting out probably 8-900 for my RE XXX 12". Good luck, and that 13W7 is a hell of a sub. Very loud with correct setup.
MalBandito99
Postby WortownSolara » Wed Dec 01, 2004 8:13 am
im telling ya man, this Xstatic stuff is incredible, i cant beleive some of the audio systems we are getting away wiht here at the store. SICK! there is an Xstatic store on Ebay too. Though not a helluva discount. But look at the Batcap 400 and a Supercap 35 Mal.
WortownSolara
Audio Guru
Audio Guru
Postby krawzyazn » Wed Dec 01, 2004 11:29 am
SleeperSolara wrote:Yeah man go wit Kicker.
ported hmm for kicker
sealed is the way to go i went through both ported and sealed and the sealed hits alot harder then the ported box
Postby B_Master_Flash » Thu Dec 02, 2004 12:04 pm
Im sorry to hear your ported box sucked. Ported boxes offer a 3db gain (thats the same as doubling the wattage to your sub) at tuning frequency w/ no noticible change in transient response (if theyre correctly made). If you noticed a change in sq when you went to ported you had a crappy box.
B_Master_Flash
Postby B_Master_Flash » Thu Dec 02, 2004 12:05 pm
B_Master_Flash
Postby 209solara » Thu Dec 02, 2004 1:53 pm
i had 1 12"w7 in the jl high out put box in my camry, running off the jl 1000/1 amp. hit rediculously hard, but destroyed electrical. got a bigger alternator and that lasted...for 6 months. when i got the solara i went with 2 jl10w7's in a cusom floor box.(no more spare tire!!!) using 2 1000/1 amps. that was completly insane, but this time i used a 15 farad cap by alumapro. that cap did wonders for those long deep hits. if your only comparing 1 13.5w7 the 2 kickers will obviously put out more. the issue of more surface area has already been touched.
209solara
Postby 209solara » Thu Dec 02, 2004 1:54 pm
209solara
Postby 209solara » Thu Dec 02, 2004 1:55 pm
209solara
