SolaraGuy.com • View topic - what offset for 18" wheels?
Postby nkx1 » Mon Sep 09, 2002 5:43 pm
Well I am finally selling my '92 Integra, so I'll have some cash to buy the 18" wheels I'm looking at. One question though:
What offset should I get? Also, please post pics if possible along with the offset in the pics. :D
Thanks!
2001 SLE, Diamond White Pearl
nkx1
Postby Jay » Mon Sep 09, 2002 10:10 pm
If the width is 8, then get 42mm offset.
If the width is 7.5, get 38-40mm offset.
Make sure you don't get 45mm. They will be too tucked in... Ugly..
Jay
Postby nkx1 » Mon Sep 09, 2002 10:29 pm
yeah the ones i'm looking at are 8" wide. Thanks!
nkx1
Postby Jay » Mon Sep 09, 2002 11:20 pm
Actually 40mm might be fine as well..
So what if you have to roll the fender?
The rims I got (Konig Tantrum 19 X 8 ) 8) only comes in 45mm offset..
I am planning on getting some 1/4 inch spacers for my rear... That should put the offset at about 40mm.
Jay
Postby nkx1 » Sun Sep 15, 2002 9:19 am
Hey Jay (or anyone else)-
I was thinking about these Kaotik wheels, but only come in an 18x7 in 42mm offset. Would these stick in too much because of the offset and the 7" width?
Here's the wheels:
www.kaotikstreetalloys.com/z-5_details.php[/img]
nkx1
Postby Jay » Sun Sep 15, 2002 9:53 am
Hi,
If wheels are tucked in too much, they will rub the springs, but 18X7 with 42 mm offset won't because it's not wide enough...
It will be about half inches tucked in more than 18X8 with 42mm.
To be exact:
7in/2 = 3.5 in.
3.5 in = 88.9mm.
88.9mm - 42mm= 46.9mm
8in/2 = 4in.
4 in = 101.6mm.
101.6mm - 42mm = 59.6mm
Besically 18 X 7 will stick out 46.9mm from the hub and 18 X 8 will stick out 59.6mm from the hub.
If you don't mind how factory rims are set up, I don't think you will have much problem with 18X7 with 42mm. They will be tucked in but not as much as the factory rims...
One solution is to get some wheel spacers. I recommend 1/4 inch spacers.
Good luck
Jay
Jay
Postby nkx1 » Sun Sep 15, 2002 10:21 am
cool. thanks so much for the info! 8)
nkx1
Postby rnsmelody » Sun Sep 15, 2002 7:22 pm
if anyone is looking for some rims.. check out www.adrwheels.com and pm for pricing
rnsmelody
Postby _eyedea » Wed Sep 18, 2002 11:51 pm
i got some 18 by7.5 with an offset of 42. I thought i was well within the range. After the install of the lowering spring set...the tyres seems tucked in good, but the spacing btwn the fender is like minimal. Talk abt rolling the fenders, howdo i go abt doing that? can i do it myself or do i have to go to the shop. I also have a big ass heavy speaker box coz of the 2 ten inch polk audio momos subs which means the ride looks like its carrying a whole heap'a potatoes. Can i put a spacer to lift the car a little bit?
just moded 2k solara * new to this isht*
18* katana concepts on falken 245/40/'18
sprint lowering springs
Clarion vrx610
Clarion Cd changer
Playstation 2
Clarion Tv tuner
Etc Etc blah blah......
_eyedea
Postby Flipside909 » Thu Sep 19, 2002 12:38 am
_eyedea wrote:Can i put a spacer to lift the car a little bit?
Nope, no such thing. If you want real height adjustment, you need to look at a real coilover system, otherwise you are out of luck with the sag you are getting.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby Jay » Thu Sep 19, 2002 8:19 am
LIfting kits are only for trucks and SUVs.
Jay
Postby nkx1 » Thu Sep 19, 2002 10:41 am
Damn that sucks about the 18 X 7.5 w/ 42 offset not fitting. I guess I'm really going to have problems lowering with 18 x 8 w/ 40 offset. Oh well, maybe I'll have to shave the wheels to get a higher offset.
nkx1
Postby happy_aggies » Thu Sep 19, 2002 2:36 pm
nkx1,
I think 18x7.5 w/ 42 offset should fit Solara.
happy_aggies
Postby _eyedea » Thu Sep 19, 2002 8:19 pm
it fits, but without me inside the car, i cant put my index finger, (or middle finger) btwn the fender and the tire.
Clarion vrx610
Clarion Cd changer
Playstation 2
Clarion Tv tuner
_eyedea
Users browsing this forum: Google [Bot] and 22 guests
