SolaraGuy.com • View topic - 99 solara v6 119,000 miles with oil leak
Postby corlon » Mon May 18, 2009 2:30 pm
have a oil leak on my 99 v6 solara. 119,000. had a buddy look at it and he thinks its either the cam seals or the crank seal. the oil leaks on the passenger side near the belts. has nayone experienced this or know if one is more likely then the other. also, what costs are involved if i bring it to a shop. thanks.
NiCe
corlon
Postby x61485x » Mon May 18, 2009 3:02 pm
http://www.solaraguy.com/viewtopic.php? ... highlight=
long story short
cam cover + power steering leaking = $1114 in repairs
2006 G35 Coupe
1999 Solara SLE V6 Auto Silverstream (sold)
x61485x
Postby corlon » Mon May 18, 2009 3:44 pm
i had a buddy at work look underneath it and said that there is another aluminum pan attached to the steel oil pan? That is where its leaking just wondering what this component is? the clutch inspection plate is also attached, maybe a cooler of some sort?
NiCe
corlon
Postby ASG14 » Mon May 18, 2009 4:03 pm
The seals leak, like any others. They should be changed WITH the timing belt. To replace them, you need to take the timing belt off.
ASG14
Postby ampreston85 » Wed May 20, 2009 2:04 am
Ya ^^^ i second that... Although i had this problem about 2 weeks ago with my previous car... If it's not leaking from the top of the engine down, then that eliminates any valve issue... Turned out to be a crank position sensor that was causing the leak... 150-200$ fix for part and labor. lol i could be wrong tho
ampreston85
Re: 99 solara v6 119,000 miles with oil leak
Postby RandySolara » Thu May 21, 2009 8:15 pm
corlon wrote:have a oil leak on my 99 v6 solara. 119,000. had a buddy look at it and he thinks its either the cam seals or the crank seal. the oil leaks on the passenger side near the belts. has nayone experienced this or know if one is more likely then the other. also, what costs are involved if i bring it to a shop. thanks.
Oil leak ? engine problem ? sell it and buy another car. No need to think :) heeheheh i did this to my old 99 Automatic SLE v6, my problem was simple everythin was good just the Gasshopper when i do speed thing. It didnt wanna go fast when i speed up it hopping like a grasshopper.
RandySolara
BAN sticked
Postby corlon » Thu May 21, 2009 8:18 pm
sorry, what?
NiCe
corlon
Postby RandySolara » Thu May 21, 2009 8:24 pm
corlon wrote:sorry, what?
I was joking, hey Corlon u just done replaced new Belt n Pump right ? maybe the guy didnt do properly, thats why ur oil is leak.
RandySolara
BAN sticked
Users browsing this forum: No registered users and 168 guests
